Question about Vizio VP322 32 in. Plasma TV
I go to turn it on and the vizio label turns white then clicks off
    Problem Solver:
  • 5 Answers
The Vizio VP322 is notorious for having bad capacitors on the power supply circuit board. They will probably be bulging and may have electrolyte leaking. I replaced four bad capacitors (with a different brand just in case) and fixed it. Total cost under $10. A lot cheaper and better than replacing the whole circuit board which may contain the same "faulty" capacitors from the factory.
Posted on Dec 01, 2009
  • 4 Answers
I replaced 3 capacitors and fixed this problem. They were 1-10v 1000uF and 2- 10v 3300uF electrolitic board mount capacitors. Easy to spot on the power board, the tops were bulged up. $5.54 later it works perfectly now.
Posted on Dec 28, 2009
3 Suggested Answers
djchillsnyc
  • 151 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
budmrtn
  • 11361 Answers
SOURCE: my vizio gv47lf turns itself off. once the on
It can be power supply failure due to bad caps, or it detects shorted circuits in the set so it goes into shutdown mode.
Look at the power supply first for any bad caps, burnt components, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 07, 2010
Why won't my Vizio 42" LCD turn on?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Apr 27, 2014 | Vizio 42 in. LCD TV
Vizio VO47L FHDTV10A wont turn on, logo goes from amber to white, tv clicks once and wont turn on. remote will try to turn the tv on. suggestions?
check your inverter board and wires 2 make shure there not arking. then check your six transformers on your inverter with volt meter
Jan 31, 2013 | Televison & Video
How to hook up a vcr
Click on the link below to download the user guide. Once done so please open it and go to page 11. Once on page 11 you should see a diagram on the bottom half of the page. On that diagram please locate the word "GOOD." Most VCR devices use this connection with a Yellow, Red, and White.
  • If this is not the cable you are using please reference to the Component Cable which is labeled as "BETTER."
  • If using coxial (thick black cable that screws in) please screw in to the back of the TV and select the channel that your VCR is set to. (Note: You may have to change your turner mode to Antenna. Please referance page 24 of the user guide to chage that option.)
As seen in the diagram please make sure that the yellow cable is connected to the Y/V (Green port / First of the five starting from the left) connection at the back of the TV. As for the Red and White cable please insert them to the Red and White connection. (Last two starting from the left / White label as "L" and Red label as "R")
  • For Component cables please connect them to their corresponding colors or labels from the VCR to the TV.
Once you have all cables connected to the TV please make sure your TV is turned on and select "Input" on the top left of your remote. On the TV you should see a list label as "Input Source Selection" or something similar. (Please reference page 16 of the user guide) Using your up or down button on the remote please select the option Comp/AV (If it only has AV and no Comp please select AV and vice versa) and press OK.
You should now be able to view your VCR.
http://www.vizio.com/documents/downloads/hdtv/E390VL/UM_E390VL.pdf
Dec 06, 2012 | Vizio 39" E390VL Full HD LCD TV, Black
Vizio VF550M Turns on but no picture
The TV has developed some on board defects and this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Vizio VF550M 55 in. LCD HDTV
Jun 25, 2009 | Vizio VO47L 47 in. LCD TV
Vizio VP322 32 in. Plasma TV Logo
598 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
