Question about Whirlpool GEQ9800P Electric Dryer
My Dryer Heats but won't tumble
When I set the timer on my dryer, I push the start button but nothing happens. I hear a click sound but no tumble. The heat element comes on and the light works when I open the door.
  • 3 more comments
  • illtryit Jan 09, 2008
    The dryer works only when holding down the start button. Any fixes?
  • Anonymous Feb 10, 2008
    My dryer humms when I set the timer. Will not start when I press the start button. What's wrong?
  • sscales24 Aug 26, 2008
    I was drying a pair of shoes and heard the dryer bind and make a wierd noise. Then it stopped. The light works when you open the door, but nothing happens when I push the button. Just a click. Any solutions???
  • Anonymous Mar 23, 2014
    Dryer comes on however, when I hit start it just clicks and nothing happens
  • Anonymous Mar 31, 2014
    Start button clicks, but the dryer doesn't start up. No tumble motion, no heat.
    Sergeant:
    Champion:
  • 262 Answers
Do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Posted on Jan 08, 2008
6ya staff
SOURCE:
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 11, 2013 | Amana Dryers
Kitchenaid prestige dryer will not tumble
I fixed one that would not run last Halloween. A Kenmore very similar to a kitchen-aid dryer:
4 Wheel dryer DE-mystatified
Jul 08, 2012 | Dryers
When I push the start button on my Kenmore 700 series dryer nothing happens. You can hear the timer clicking as if it is getting power, but the dryer doesn't come on. Could this be a defective timer?
Check the door saftey switch and the start button for continuety.
My bet is the door switch.
Then look at the timer if both those are good.
Mar 19, 2010 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer timer or start will not work
Yes, it does sound like the timer. You could do an ohms test if you have the ability but timers aren't too terribly expensive or hard to replace anyway.
Apr 08, 2009 | Kenmore Dryers
Dryer heats up but won't turn
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Nov 27, 2008 | Dryers
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Jun 12, 2008 | Kenmore Dryers
Dryer wont come on
check the voltage at the outlet for 220
Feb 16, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool GEQ9800P Electric Dryer Logo
404 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
