Question about Aiwa Audio Players & Recorders
Aiwa AP-2300c, the speed controls do not come up
Aiwa AP-2300c direct drive audio turntable, the speed controls do not come up to full speed. Are there internal adjustments and which potentiometer are they?
4 Suggested Answers
  • 4 Answers
SOURCE: Aiwa AP-2600 Direct Drive Turntable. Purchased
Have you had a look at the drive belt below turntable could possibly need replaced with new one.
Posted on Mar 05, 2010
  • 49 Answers
SOURCE: Aiwa AP-2600 Direct Drive Turntable - platter not rotating
if the platter is removable by you and easily, might need just a little cleaning and lube at the center . the platter is the top rotating plate that you were pushing to get started.simply pulls out around a center key. check with local service shops how much they would charge for this kind of cleaning and lubing. $25.00 might be a good price to allow a decision, whether to buy a new.
Posted on Mar 06, 2010
SOURCE: Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Posted on Apr 03, 2011
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
I am trying to play a record on my Aiwa LX-120 turntable but after scanning the record the arm won`t go down.
I'm not certain that you are meant to disengage the FG lock since this means that the turntable has achieved the correct speed. The problem you have is that the arm won't go down.
I don't know to much about the workings of this direct drive turntable. But I can say you can get the service manual free on-line if that helps.
May 01, 2015 | Aiwa Audio Players & Recorders
My turntable speed is slow on 33 1/2 what can be done to correct?
if this is direct drive you can speed this up w pitch control...belt drive the belt is loose you need to purchase another belt...take wheel off and measure the inside of the wheel (the belt is no more than 2-3 dollars)
May 22, 2010 | ION Audio TTUSB10 Turntable
Mar 05, 2010 | Aiwa PX-E860 Turntable
My akai ap 206c direct drive player has just stopped for no reason it seems. Power and all leads are ok.
I have a 206 and a 207 both had dirty pots the speed controllers had to be pryed apart sprayed with cleaner they now work great.I hope this helps.
Dec 31, 2009 | Audio Players & Recorders
Hi!
Have Aiwa CX-NA555 with 3-CD turntable. CD's won't play because belt that connects motor to screw-drive on turntable is broken. Where can I get part number and/or replacement belt? Tx.
i have an aiwa cx-na555, the turn table want work the belt is good however when the table slides in it does not raise the turntablr motor into position because the yrllow does not unlock the turntable, its as though it is out of time, ineed help
Dec 07, 2009 | Aiwa Audio Players & Recorders
TURNTABLE SPEED TOO SLOW. IS THERE ANY WAY TO ADJUST IT.
The liely cause of the slow speed problem is the belt. Your turntable is belt driven, like components in your car's engine compartment. As the belt ages, it can begin to slip. Replacement of the belt will probably restore the speed once again. The PX-E860 turntable has been discontinued. There are parts, such as the belt, that are still available. How much longer these parts will be available for remains unknown. If you like the the turntable, you should consider purchasing several belts as the next time you need one, they may not be available or may cost much more.
One source for replacement belts (there may be many others, ie: eBay):
http://www.elexatelier.com/aiwa.htm
You might also need a manual to direct you as to how to go about changing the belt. The manual is a free (after registering) download below:
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Oct 05, 2009 | Aiwa PX-E860 Turntable
Turntable not turning to play record............. power on............ please help my email address - diatmesa@aol.com
This could be many things like the following>
If its a direct drive turntable the motor could be "blown",
or motor electonic speed controller burnt out.
If its a belt drive turntable then the belt could be broken
or stretched and is slipping, or the belt can have dropped of a drive pullety.
Also there are speed control mechanisms to adjust the final speed of the
turntable to the recorded speed of the record like 331/3rpm, 45rpm 75rpm
These speed reducing mechanisims can slip and cause the turntable not to turn..
There are also other mechanical bits that slide and push against each other,
and these can get sticky and the friction increases so much that the power
from the motor drive causes the belts to slip, so you need to identify if a
friction problem exists as well..
If you are carefull you can look your self and find out which one of the above it is.
Be warned there are lethal voltages inside the turntable which can kill you....
so please dont have the power on when making any inspection or adjustments.
Cheers From YUBEUT..
Jul 22, 2008 | Teac GF-350 CD Shelf System
62 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
