Question about Teac AG-D8900 Receiver
How to remove the protect signal
Teac AG-D8900 AV reciver how to remove protect signal
  • 70 Answers
Make sure that your input level are not too high. They will cause the an overload in the receiver and it will clip the circuit. This will continue until you lower the level of the input that you have on at that time.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Posted on Nov 12, 2009
From the owners manual in the troubleshooting section,
"Protect" is diplayed
> Check the connections to the speakers
Have no idea if this is it, but that is all it says.
Posted on May 23, 2010
Hi, i write a new post for people who have theses sames problem that i had yesterday and for months with my Teac AV-H 500 D amp.
The problem was protec mode, and very loud electrical noise. ( In some cases it doesn't product the electrical noise )
The consequence was no sound in the speakers.
Here is the solution :
Search when then tension arrives, just after you found where the tension cable is, open the amplifier, and search the card who is connected with.
It's generaly in front of, u must retire this card ( its better if you doesn't disconnect any cable, if possible, i recommand it)
For my model I can retire it, but i must retire the big power transformer too on the right ( Teac AV-H 500 D)
After retinring this card, u will see, attached to this card a metal block, who is put down in a small metal conductor of maybe 2 cm long.
This is the problem, the amplifier may be old, and the connection between the metal block and the connection is poor.
For me, i just polished a little the metal block, and i putted a small plastical piece for upping the mother circuit card, for narrow.
( NEVER USE CONDUCTIVE MATERIAL FOR IT)
After it was ok but the last precision :
( BE CAREFUL ANY SOLDERING IS TOUCHING THE EXTERNAL METAL BAG)
I want to tell this is dangerous because this part of the circuit is directly in contact with tension so
ALWAYS OPAIR WITH THE TENSION DISCONNECTED :)
because the amplifier putted off the tension is also operative !
Thanks for reading and im glad if it helps you !
Posted on Jan 15, 2010
IT BLINKS PROTECT
It might be overheating. Make sure there is proper ventilation space all around unit. If that does not do it you might have an internal fan burned out.
Mar 14, 2014 | Teac AG-D8900 Receiver
Can I hook a turntable to a Teac AG-D8900. Where do I input?
only if the unit has a PHONO input never plug a turntable into any other jack as teh voltage is different.
I have seen an adapter so that you can plug a turntable into an ordinary input I believe Radio Shack but that was along time ago try ebay
Jan 08, 2010 | Teac AG-D8900 Receiver
Teac AG D8900 II sub woofer not working
click on the blue "teac sub woofer" link top of page, solution is in my response to another with same problem-that is at least 3 of us with this now.
JS
Dec 26, 2008 | Teac AG-D8900 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
TEAC DIGITAL HOME RECEIVER AGD 8900 AV
I changed the diodos from power supply.
I thought that help you offered
was free,but I forget that nothing here is free.
Thank you anyway
Dec 15, 2008 | Teac AG-D8900 Receiver
Teac AG- D8900
Stereo Tech: Check speaker switch(A or B) also be sure you have selected FM, AM, Video, CD ect., somtimes if you do not have a stereo signal the unit will mute best to fist try tape or CD input. Hope I helped good luck.
Nov 27, 2007 | Teac AG-D8900 Receiver
Teac g-v8520 protect problem
Check the thermal sensor, TH1. This causes the unit to go into protect, it is a common failure part on this model.
Oct 26, 2007 | Teac AG-D8900 Receiver
Power comes on but speakers do not make noise
Stereo Tech: yes their is a fuse inside that possibly opened, but does the unit show PROTECT across the display? if not you may have goten lucky and just did a fuse small PC board just behind the transformer. Good Luck
Jan 14, 2007 | Teac AG-D8900 Receiver
Setting Up The System
You can find the requested details at: http://www.teac.com.au/file/product_manual_408.pdf
Mar 09, 2006 | Teac AG-D8900 Receiver
Protect
You may have shorted the speaker wires. Remove all wires from the output connections and make doubly sure no strands are left there. Turn volume to zero and turn the receiver on. If the problem persists, you probably fried the output stage. Have it repaired.
Jan 22, 2006 | Teac AG-D8900 Receiver
Teac AG-D8900 Receiver Logo
997 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
