Question about Fuji FinePix J10 Digital Camera
CANNOT TAKE PICTURES SHOWING PROTECTED CARD
CANNOT TAKE PICTURES SHOWING PROTECTED CARD MESSAGE
  • Stephan Reichert
    Stephan Reichert May 11, 2010
    Okay. Firstly remove you sd card and move the little white lever (write protection switch) to the top. Now reinsert the card into the camera and it should work. If it doesn't work , the error is probably with your camera. If you open your sd slot of your camera and look inside with a bright light , you
    should be able to see on the left side of the slot there is a little
    copper or spring steel lever switch. This switch work as follows: 1. When no card is inserted / no write protection , the switch is open and thus the protection is off. 2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock. Contrary
    to popular belief ,the little tab on the sd card is not an electronic
    switch and does not physically influence the card operation itself. If
    you put a locked card into a camera without a sd lock switch , you
    would still be able to use the card normally. It is incredible
    difficult to fix this switch because of space limitations in the sd
    card slot. Look into the sd slot and if you can see the switch , use a pin
    or sowing needle to pull the little tab down toward the base of the
    camera by about 2mm or until it works being careful not to bend it. If
    this does not resolve your problem , there might be a short in the
    switch circuit and the camera will need to be disassembled to resolve
    this error. This should cost no more than $50. Please feel free to contact me if you need further information Kind regards Stephan
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Oct 07, 2014
SOURCE: how to unprotect the memory card
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
Posted on Sep 18, 2008
peeface
  • 180 Answers
SOURCE: I get the message "Protected Card"
on your memory card is a little switch thing. if it doesnt work one way try putting the switch in the other position
Posted on Jan 30, 2009
fblock
  • 289 Answers
SOURCE: Card write protected
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Posted on Apr 28, 2009
  • 102366 Answers
SOURCE: memory card is write protected
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on May 25, 2010
  • 102366 Answers
SOURCE: protected card message
Posted on Jul 22, 2010
Camera won't take pictures it show protected card
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 23, 2014 | FUJIFILM A220 Digital Camera
Protected card
On the edge of the card, there is a TINY switch. Slide it to the 'unlock' position.
Aug 21, 2013 | Fuji FinePix S1000FD Digital Camera
Protected card message
Jul 22, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
A memory card "write protected"
Get a card reader and download the pics from the card to your computer. Then, format the card in the camera.
Dec 23, 2009 | Cameras
Canon rebel xsi gets message card write protected with or without sd card
hi, when i turn on my camera the screen says card write protected? and I can't take pictures on my canon xsi
Jul 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
I cant copy song in memory card its shows card is write protected
What sort of memory card is it?  can you remove it and install it in a card reader directly on your pc?  What is trhe phone?
Jan 14, 2009 | Motorola Mobility ROKR E6 Smartphone
How to unprotect the memory card
May 18, 2008 | Microtek Take-it MV320 Digital Camera
When swithched on the camera getting message protected card and unable to shoot photos
Try to slide the little switch on the side of the card in the other direction. That switch is like a write protect for the card. Good Luck.
Nov 16, 2007 | Gateway DC-T50 Digital Camera
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Fuji FinePix J10 Digital Camera Logo
143 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
