Question about Bose & Wave& Music System
My denon udcm m7 personal component system cd player often gives an error message (ERR) when I hit play or eject on all three disc. I have to keep turing it off and trying again before it actually, randomly plays or ejects. I have had it repaired before, but the problem persist.
This was addressed in http://www.fixya.com/support/t557928-denon_udcm_m7_cd_player_often_reads_err
Posted on Apr 30, 2010
How to remove a jammed cd out of a car cd player
I hope you don't use the DCM-360 in your car. You should be able to eject the CD, with pressing the eject button, several times. It could be the eject mechanism is defect, or someone pressed the CD too far, r even some debris came in the player, after the ce was inserted.
In most cases, you really should remove the player en open it. to avoid more damage than already exists
May 02, 2014 | Denon DCM-360 5-Disc CD Changer
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
Delco factory Radio/CD player,it gives an err msg.and ejects CD
The laser in the cd player may be dirty or has gone bad and can no longer read the disc.
Apr 17, 2010 | 1998 Chevrolet S-10 Pickup
How to get service manual - Denon M10 (UDCM-M10) - CD Player
I woul try to download it from a reliable site and print or see if Denon sells it
Feb 09, 2010 | Denon D-M10 CD Shelf System
Infiniti g35 sedan cd err fo message.
had the same problem, it's a recurring problem w/G35 but Infinity will make you pay for the replacement (google it to see how many others have the issue)
Mar 04, 2009 | 2004 Infiniti G35 Sport Coupe
2003 audi a6 cd player error 2
HI,THE REASON YOU ARE GETTING AN ERROR MESSAGE IS BECAUSE THE MECHANISM IS FAULTY,YOU WILL HAVE TO HAVE IT REPAIRED,ANDY
Dec 02, 2008 | 2003 Audi A6
Denon CD unit will not play due to err
The problem is in the mechanism,maybe when you put another disc while playing that is cause. There is a misaligment there in the tray you better checked it out,and also the lense by using a cotton buds.thats all for now Hespbb....
Jun 19, 2008 | Denon Audio Players & Recorders
Denon udcm m7 cd player often reads ERR on play and eject
Try cleaning the laser first. Take care, because it is delicate.
Some instructions of how to clean a CD laser:
http://www.wikihow.com/Clean-a-CD-Player
If the cleaning does not fix the fault, it is possible that the laser is weak, or there are some problems in the electronics in the CD player. This is not something you will be able to service yourself, unless you are properly trained, have experience, and have the proper setup to perform CD player servicing.
In most cases these CD players are not cost effective to service. You can contact the orignal manufacture for details or any recomendations.
Jerry G.
Apr 29, 2008 | Bose & Wave& Music System
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
Bose & Wave& Music System Logo
497 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
