I have a Konica Minolta Bixhub C550. The confirmations currently print on legal size paper from tray 1. I can I change the settings so that the fax confirmations will print on regular letter size paper. Thanks!
    President:
  • 3,085 Answers
Reports and confirmations will only print from tray 1, Have you tried putting letter size paper in tray 1 and using tray 2 for legal size?
Posted on Nov 12, 2009
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Bizhub 600 reads wrong paper size in tray 1
Is tray 2 OK?
Any paper stuck behind the draw. Check the setting off draw one in user mode is it for that size paper?
Apr 23, 2013 | Konica Minolta Bizhub 600 750 Image...
Paper tray see's legal size and we need it to be letter size paper
Usually there is a setting in your menu to change the paper settings, if not look in the tray itself and see if there is a size on it and change it there.
Mar 22, 2010 | Konica Minolta magicolor 2300DL Laser...
How do I print 8-1/2" x 14" paper. I only have one 8-1/2" x 11" tray? Konica Minolta Magicolor 5430DL
On the 5430 DL there is an aux legal tray that can be purchased for legal printing. On a later successor the 5550 a manual feed option was included, however for the 5430 there is no option for printing legal without the extra tray being installed. On a side note, I have this tray and when not printing legal it lets me load an extra 500 sheets of letter paper which is very convenient when I need to print a bunch of sheets overnight.
Mar 15, 2010 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta 5430DL second tray - print dialogue
This needs to be setup through the computer using the printer properties, not through the printer. You will need to be the local admin to make the changes. You may also have to go under advance and manual specify the tray and component types. The printer will not allow you to set options for trays and components that are not enabled or detected. Let me know if you need a step-by-step.
Nov 08, 2009 | Konica Minolta Magicolor 2530 DL Laser...
My photocopier has 3 drawers - First is universal and 2 & 3 are both set at letter. I would like to set drawer 3 to legal. how do I get the copier to recognize the change?
Please specify the models.Also the Minolta copiers paper tray change:Press utility key-User choice-paper set or
Utility-Meter count-Stop-0-Stop-0-0-1 Paper size input :set the paper size used in each paper source.Touch the key of paper sorce for wich the paper size setting is to be changed to show the paper size input screen.Touch the desired paper size keys.Touch END to validate the paper size setting.
Please look the mechanical setting in the trays.If so need,change.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
Minolta Magic Color 2300dl printer won't print legal size documen
Is tray one the bypass tray or a tray. check which one is tray 1
Nov 24, 2008 | Minolta magicolor 2300W Laser Printer
Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Pagr pro 9100 and Mac OSx 10.5.1
I am not clear with the quarry you ask but what I understand that you can print larger the A4.so in all Konica Minolta printers which I have used we must specify the paper size before printing in the printer properties and confirm that the same paper size we have putt in the printer’s tray. if more then one trays and installed in the printer the printer can print all available paper size without specify them. But spouse if you send a legal size print to the printer and there in no legal size paper in the paper tray then it will show a error.
What I think it is paper size issues please check it and make sure the trays are fixed to the size which you putt in.
Jan 24, 2008 | Konica Minolta PP9100 N Economical...
200 people viewed this question
jasbo
jasbo
