Question about Brother MFC-9440CN Laser Printer
Smudging across the page.
Smudged text across printed pages Drum has gunk on it that is not easily removed. I'm wondering if there's any chance of repairing or cleaning the drum versus buying a new one? The printer isn't really old enough to justify already having to buy a new drum.
    Genius:
  • 1,018 Answers
Here is a generic question I would like you to consider.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If this does not apply to then do not worry about it.
My concern is that the gunk you are seeing is caused by toner leakage. To the best of my knowledge, current day drums cannot be serviced. They have to be replaced. Wiping the drum will scratch the surface and you would still need to replace the drum.
Also, it may be that you are at the "End of life" for the drum.
My suggestion would be to have the printer serviced by an authorized repair technician.
Don
Posted on Nov 12, 2009
Canon PIXMA iP4200 not printing PGBK properly - only printing top 50% of PGBK grid on test page.
Man you did some awesome troubleshooting! I don't know, but it sounds like something is physically wrong with internal electronics. I'd call in the big dogs at Canon themselves.
https://www.usa.canon.com/internet/portal/us/home/contactus
Nov 17, 2016 | Canon PIXMA iP4200 InkJet Photo Printer
Color smudging
Hi, either the drum or belt or both become defective.
Dec 16, 2013 | Samsung CLP 300 Laser Printer
HP4-smudged copies of printed text are appearing lower on the page...Any ideas on the fix
Run a 1/2 test.
Put paper in the manual feed tray(tray 1).
print something. And watch the paper. As the paper gets
about 1/2 way into the printer, open the top cover, remove the toner.
Look down at the paper. If you don't see smudged text, the fuser is probably bad.
If you see the smudging, replace the toner.
Dec 02, 2010 | HP : HP4 Laserjet Printer
Vertical lines of missing print
I'd certainly be swapping the fuser first although I know how expensive they can be and what a pain they can be to get at. You've tried everything else I would start with and as the text is smudging I'd certainly be testing the fuser next. Scott.
Dec 12, 2009 | Konica Minolta magicolor 2500 Printer
Vertical dark/smudged line on right side of paper when printing
See its a very common issue.the right side of the drum has moisture on it.remove the toner and drum and apply a hot air blower on it for some time also clean the printer internally.reinsert the toner and drum.
check by printing few pages the smudging on the right should go within 10 to 12 pages.
if the smudging doesnot go away then its time to replace the drum to solve the issue.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 11, 2009 | Brother HL4040CN Laser Printer
Printer is smudging ink/transfering onto innapproriate pages
take the ink cartridges out; clean them with a q-tip and rubbing alcohol, clean each cartridge; let it dry and then run a test page
May 04, 2009 | Xerox Phaser 6130 Laser Printer
Printer smudging caused by self-sealing envelope glue on drum
Drums are not hot, you can try to clean them, are they smudgy? More likely the glue came off when it hit the hot section check this area, be carefull not to scratch anything.
-Carl
Apr 09, 2009 | Ricoh Aficio CL3500N Laser Printer
Brother MFC 7820N Smudging Concern
If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Smudging and overlapping
By smudging do you mean the print is actually rubbing off?
I am going to assume you are seeing some reprint on all printed pages.
If I am understanding correctly, what you have is a bad fuser, most likely a bad heat roller.
That is the heated area just before the pages exit the machine.
The coating on those rolls wear out with time, or may even debond from the aluminum. The ink does not then properly melt into the paper, sticks to the roller and progressively becomes worse.
Replacement of the fuser should resolve that issue. That's simply a normal wear item.
Mar 14, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother MFC-9440CN Laser Printer Logo
178 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
