Question about Sony Cyber-Shot DSC-P52 Digital Camera
My camara lense cover does not get close and when i open it sat giving noise asking to switch off and then on .I changed the battaries,but no use.please help
    Problem Solver:
  • 14 Answers
The best solution is to send the product back to the manufacturer for repair or replacement. If you have a receipt for the product and its within the warranty period (1 year) they will do this free of charge. I can help you with the process.
Muzu
Posted on Nov 12, 2009
Sir/Mam, I had purchase Sony
Has it been dropped? I had a cabera that was dropped and the lense would not go all the way back in which caused the lense covers to not close.
Oct 22, 2013 | Sony Cyber-Shot DSC-W570 Digital Camera
My Toshiba e-studio 233 copier is giving the error message, "Close side cover." Opening any cover to close again changes the message to "Close x" where x is the part opened, until that...
there is a switch at the side that is being push by the cover when it closes check this switch to be sure it hits the button when close or you may replace the switch it has a problem.
Jun 27, 2011 | Office Equipment & Supplies
Sir, My mobile is Nokia 6500 model. In contact settings,at first it was set as contacts>>settings>>"memory in use"-PHONE AND SIM. By mistake I have changed the option of "memory in use" to...
usually the phone memory security code for nokia mobiles will be 12345, until it is changed manually. try this code... else, u have to consult the service provider i guess.
memory card not detecting....
First you open gallery on screen. If the memory card ok the first item will be the name of your Card. If it is not found that means the card not detecting. You may do this.:
Open Gallery, then press the back ( battery cover ) of the phone and hold for one second, now see the screen, you can see the card name on first line. But when you take your hand back form the battery cover the display revert to the same as before.
The point of pressing:- near to the lense ( Just right side of the lense) . You know why ?. The memory card is located inside of that place.
This means there is a switch (Battery cover open / close) located just left side of the memory card, and there is a TIP projected in the same place at the Battery cover. When we close the back cover the switch become ON. Here is the problem.....!. The switch will not contact even you close the cover. When you press the cover hardly the switch become contact. when you remove the hand again it become open.
More clarification:-
In a new phone if you open the battery cover the memory card will not work at all. It will detect only after closing the cover.
this may help you.
Jan 08, 2010 | Nokia 6500 Slide Cellular Phone
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My easyshare m1063 will take pictures, but the pictures dont show
I have an easyshare and there's a 2 part lens cover that closes when you turn it off and opens when you turn it on - normally. Mine only closes one part of the cover when I turn it off and opens when I turn it on. Kodak said I could send it in but I may have sat on it and caused it to malfunction. In which case they wouldn't cover it. Yours sounds like it's not opening at all. Look at the lens, and if you see a flat black cover with a wavy line instead of glass when you turn it on, yours is stuck shut. If it's still under warranty they should fix it unless you sat on yours too. Consumer Reports rated these a best buy but somehow this problem fell through the cracks of their testing.
May 28, 2009 | HP Photosmart M525 Digital Camera
Sony Handycam dcr-dvd110 lense cover jammed open.
the camera should go to a repair shop immeadiately, the lense cap will be removed and replaced :)
May 23, 2009 | Video Cameras
How do I change a battery on polar monitor F6
Open Caseback. Unclip the contact. Replace battery, clip contact back and put the caseback on.
Feb 02, 2009 | Polar F11 Heart Rate Monitor
Hp photosmart r725 6.2 megapixels.
If you're getting the 18-4489-957-000 error code, then give it a good tap on the corner where the lens cap is. A little tapping and the lens cover should pop closed. When you turn the camera on again it will probably work just fine.
I was just about to junk my camera when I googled the error code and found this very tip in another thread. It worked like a charm.
May 29, 2008 | HP Photosmart R725 Digital Camera
Casio Digital Camera ex-s770 will not open
Hi, this is a problem alot of people get having with this type of camera.
It could be one of a couple of things first check the battery is fully charges as a faulty battery would cause this problem, do you have a switch on the camera that lets you see the pictures stored on it without opening the lense, not all makes and models do this some have switch you can slide and some is just push button the push button you cant do this.
So if yours is the push button one then the only thing to try if the battery isnt the problem is looking and removing anything thats caught in the side of lense.
Ok try removing battery and any mem cards if you have any in it then bang the camera firmly into the palm of your hand sort of shocking the camera to dislodge any thing thats stuck in the side of lense do this few times then replace battery and switch on usually this solves the problem.
If not then when you switch camera on grab the lense and help it come out taking it past where it gets stuck be gentle try this few times and see if camera comes on.
Once the lense is passed certain point the camera should come on.
So give that a try it does sound like something is jamming the lense so try pulling it out gently only do it when its supposed to be coming out when it trys to go back in let go again try this few times.
Failing this then the problem could be that either the camera has been put down with the lense open and forced the lense motor damaging it or the other thing that people tend to do is switch camera on acidently whilst its in pocket or case so that it switches on but the lense is blocked from coming out this causing damage to lense motor.
If the problem is in fact the lense motor then their is no way of getting this repaired they just dont repair these and you cant get the parts like lense motor no camera shop will even look at them as you cant get parts and also price of repair would cost more than replacing the camera.
Also check to see if your lense turns round as its coming in or out if it does this then try turning the lense as its coming out.
Let me know how you get on ok and ill try assist you further
Feb 22, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Camara won't come on
It could be the batteries. To be sure about it, try your batteries in another appropriate appliance. Good luck!
Sep 07, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Sony Cyber-Shot DSC-P52 Digital Camera Logo
70 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
