Question about New World G90m Gas Double Oven
New world plan 6 we5224 n00 cooker - oven ignition works but fails to light. no gas smell present.
  • devononearth May 11, 2010
    There is an electric solenoid in the gas supply to the oven. This is switched by electric supply through the programmer (if you've got one) and then the oven knob / thermostat. I known this from the wiring diagram on the back of our cooker.
    It is probable that your solenoid has failed.
    I don't know where to start looking for a replacement.
    Ours needs a programmer!
4 Suggested Answers
  • 447 Answers
SOURCE: gas mark nob not having any effect on gas levels
Time to change the thermostat. the cap tube sounds like it has been broken. If it has a temp control board, change the temp probe. The clicking sound, if unit is equiped with an ignition control modual, is bad, (not shutting off after sensing pilot) or sensor rod is dirty.
Posted on Dec 23, 2009
heatman101
  • 43501 Answers
SOURCE: oven doesn't turn on. pluged in indicator lights
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jun 01, 2010
  • 417 Answers
SOURCE: new world vision cooker main oven wont heat up fan
If it's pulling out the trip it will be a faulty heating element, you will need to get it replaced
Posted on Dec 19, 2010
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
Ignition not working although there is power to the cooker (oven fan working)
we turned it off at the plug left it for a 5 minutes it then worked again
Jul 27, 2011 | New World G70m Gas Double Oven
Gas wont stay lit after ignition
Oven not Working or
Oven not Heating
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
Oven doesn't turn on. pluged in indicator lights on, slight smell of gas present. seems that it's not igniting
heatman101
Jun 01, 2010 | Vulcan SG4D Gas Single Oven
Gas mark nob not having any effect on gas levels in the oven seems like it is on its highest setting all the time? Also the ignition keeps clicking away all the time could this be a s/c on the wire from...
Dec 23, 2009 | New World G60m Gas Single Oven
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Lights are on but burner will not light!
it sounds like your fail safe has gone the only person who can take that job on is a gas cooker in staler if you have a second hand shop that sells appliances then they could help or even take on the job less then the gas repair man try them
Jan 07, 2008 | GE JGRS14 Gas Single Oven
New World G90m Gas Double Oven Logo
269 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
