Question about Dell Latitude D600 Notebook
ONE OF MY 2 USB PORTS DOES NOT WORK ON MY DELL LATITUDE D600. I TRIED THE FOLLOWING FIX, >START>RUN> DEVMGMT.MSC AND UNINSTALLED ALL USB CONTROLLERS, RESTARTED MY LAPTOP (WITH WIN XP PRO) WHICH REINSTALLED THEM. THE USB PORT STILL DOES NOT WORK. CAN YOU RECOMMEND ANOTHER FIX OR IS THIS PROBABLY A HARDWARE PROBLEM? THANKS FOR YOUR HELP, ROGER.
  • Dell Master
  • 4,806 Answers
Hi Roger,
The Windows command you used to uninstall the USB port is correct. If they all work bar one, then i think its safe to say it's possibly a hardware issue.
The only other fix i can think of is to update the BIOS with the latest version from the Dell support website.
Good luck.
Posted on Nov 12, 2009
My dell latitude d610 all USB ports do not work.how can I fix them
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Aug 15, 2012 | Dell Latitude D610 Notebook
My dell latitude d600 laptop has just been rebooted and i have no sound what do i need
You just need to download the appropriate audio driver for your motherboard. Go to the Device Manager and install all missing drivers for "Unknown Devices". Either connect to the internet or use the driver disc which came with your laptop.
For those who doesn't know how to access Device Manager, please follow the steps below.
For Windows XP:
Start -> Run -> Type devmgmt.msc (in the box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
For Windows Vista and Windows 7
Start -> Type devmgmt.msc (in the start search box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
Hope this helps.
Aug 27, 2011 | Computers & Internet
My USB can't recognized. The recommendation is this: "Try reconnecting the device. If Windows still does not recognize it, replace the device." The device works on other computers or laptops,...
Here are some steps which you can try. It is not always that the device is defective. Maybe the generic USB controller/driver needs to be uninstalled then reinstalled or the USB port itself is broken.
- Go to Device Manager -> Right click USB Controller -> select Scan for Hardware Changes.
To go to the Device Manager in xp (Start -> Run -> type devmgmt.msc -> press Enter or OK), in Vista and Windows 7 ( Start -> type devmgmt.msc on the start search box -> press Enter)
- Access BIOS setup (either Del, F2, F10...depending on the laptop brand) then look for the option to restore default BIOS settings.
- Go to the Device Manager and unistall everything under the USB Controller then restart the unit. It should automatically reinstall the driver. Try to use multiple USB devices if possible.
- If the above steps will not work, you're USB port may be defective already.
I hope this helps. Please reply if one or any of these steps resolved your issue for the benefit of other users having the same problem as yours.
Regards.
May 11, 2011 | Computers & Internet
USB Port Malfunction
use another port, or re-install drivers
Jan 17, 2011 | HEWLETT-PACKARD HP HP Pavilion G71340US...
My speakers do not play sound
try to uninstall/reinstall sound drivers on your device manager. Click start > click run > then type the word devmgmt.msc . Then on the device manager, right click realtek HD sound adapter and click Uninstall. Restart the pc and it will automatically reinstall it. If it still did not work, refer to Dell for more...
Nov 29, 2010 | Dell Inspiron B130 Notebook
Usb ports not wokring . every thing installed when in connect the mouse.its not working . but mouse lights are on. and any other usb device connect its also not wokring.
To scan for hardware changes, follow these steps:
  1. Click Start, and then click Run.
    Note If you are running Windows Vista, click Start, and then use the Start Search box.
  2. Type devmgmt.msc, and then click OK. Device Manager opens.
  3. In Device Manager, click your computer so that it is highlighted.
  4. Click Action, and then click Scan for hardware changes.
  5. Check the USB device to see whether it is working.
If scanning for new hardware did not fix the problem, try restarting the computer. After the computer has restarted, check the USB device to see whether it is working.
If restarting the computer fixed the problem
  3. Expand Universal Serial Bus controllers.
    Note You might have to scroll down the list to find this item.
  4. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it.
  5. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers.
  6. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled.
  7. Check the USB device to see whether it is working.
Oct 24, 2010 | HP NX5000 Notebook
DELL LATITUDE D600 USB PORT NOT WORKING
You can solve this issue by installing usb 2.0 driver in your DELL LATITUDE D600 laptop find Blow Drivers Download Link:
.DELL LATITUDE D600 Drivers Download Link
Feb 05, 2010 | Dell Latitude D600 Notebook
USB ports not working
Method 1: Use Device Manager to scan for hardware changes loadTOCNode(2, 'resolution'); Use Device Manager to scan for hardware changes. After your computer scans for hardware changes, it might recognize the USB device that is connected to the USB port so that you can use the device.
If scanning for hardware changes fixed the problem, you are finished. If this method did not fix the problem, go to Method 2.
Method 2: Restart the computer loadTOCNode(2, 'resolution'); If scanning for new hardware did not fix the problem, try restarting the computer. After the computer has restarted, check the USB device to see whether it is working.
If restarting the computer fixed the problem, you are finished. If this method did not fix the problem, go to Method 3.
Method 3: Disable and re-enable the USB controller loadTOCNode(2, 'resolution'); Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager.
To disable and re-enable the USB controllers, follow these steps:
Jan 02, 2010 | Evesham Axis PC Desktop
USB PORT NOT WORKING.
Both USB ports use the same driver, so if one works and one doesn't, you have a mechanically bad port. You'll need to replace the hardware to solve the problem. There are usually a lot of bad D600 motherboards on Ebay. Or try to find just the USB port you need. Fairly simple replacement task, but laptop dis-assembly will be required to reach the part.
Nov 12, 2009 | Dell Latitude D600 Notebook
ONE OF MY USB PORTS STOPPED WORKING ON MY DELL LATITUDE D600 PC NOTEBOOK.
A shot in the dark here, but try this: Click Start>Run, type devmgmt.msc and press enter. Click the plus sign beside "Universal Serial Bus Controllers." Right click each listing that appears underneath "Universal Serial Bus Controllers" and click Uninstall. Click OK on the confirmation dialogs. After you get done uninstalling all of them, restart your computer and Windows should reinstall them. After it is done, try that USB port again.
Nov 11, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
252 people viewed this question
Alun Cox
