PROBLEM; TOSHIBA 40XF355D THIN RED VERTICAL LINES APPEARING ON SCREEN. ANY SOLUTIONS PLEASE?
    President:
  • 1,284 Answers
There are 1 of 2 possibilities for this. The board mounted to the back of the LCD panel at the top of it is call the t-con board if that partially fails you will get the red lines in the picture. The other possibility is the LCD panel itself. Best to have a technician look at the TV to verify which one it is. In some cases the t-con board is not available by itself and at that point the LCD panel has to be replaced. If the TV is out of warranty you will spend less on replacing the TV if the LCD panel needs to be replaced as they run upwards of $2000.00 dollars.
Posted on Nov 12, 2009
  • 668 Answers
Chances are the LCD panel or the T-Controller is the cause of the problem. The T-Controller is mounted to the back of the LCD Panel and is what takes the information from the Main Board and feeds it to the LCD Panel. Most of these T-Controllers are sold with the LCD panels and are not available for replacement themselves. To be sure though, you can call Toshiba at 1800-631-3811 and check their Parts Department
availability of it. If it is available it would be a lot less to replace it than the LCD Panel. If it is not available, it would not be worth repairing due to cost of the LCD Panel.
This was a little drawn out but I hope it helps,
Skyassoc
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Very thin vertical red line just appeared on my monitor. It is about 5-6 inches from left side.
LCD is starting to go bad. Anytime lines start appearing randomly or constantly, the pixels are going bad so the screen needs replacing.
Nov 30, 2009 | Compaq Presario M2000 Notebook
Vertical lines appearing on my laptop screen
...not good. Generally means your screen is on it's way out.
Jun 22, 2009 | Compaq Presario M2000 Notebook
Vertical lines are appearing on my toshiba laptop
first try to hook it into an external monitor if it looks good,I would have to say you have a damaged cable on your monitor.if you are comfortable taking it apart you can try to reseat the ribbon cable on the mobo.you can usually find an online manual for disassembly.
Apr 23, 2009 | Toshiba Satellite 2455-S305 Notebook
Thin Vertical lines on the screen
Ebay - new screens $110-$135. Google for step-by-step replacement instructions.
Dec 30, 2008 | Toshiba Satellite P30 P35 Series Notebook
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Toshiba theatreview
sounds like vertical problem maybe bad solder connections on vertical ic check and get back to me
Nov 03, 2007 | Televison & Video
Televison & Video Logo
787 people viewed this question
Top Televison & Video Experts
