Question about HP Pavilion Ze4900 Notebook
The dvd rom quit ejecting. It clicks and a light flashes and nothing else...won't come out. I tried the little hole with a paper clip. nothing. How do I access it from the bottom.
  • HP Master
  • 1,183 Answers
If the optical drive is not ejecting with the emergency eject button ,it probably a bad optical drive. The repair manual is given on the link below
Go to the option that says >removal and replacement procedures>optical drives
http://www.karlin.mff.cuni.cz/~motl/hp-keyboard/manual4900.pdf
Thanks for using fixya
Proton
Posted on Nov 12, 2009
My disc is not playing nor can I eject it is there some way I can do this I have a Lenovo Think Centre M90z
The drive can be easily removed once removed you can then use the paper clip from the back and push the tray open
Jan 05, 2015 | Lenovo ThinkCentre Computers & Internet
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Door will not open on my desktop's DVD Rom Burner
There should be a hole to stick a paper clip in.....try to eject while pushing in paper clip
Nov 13, 2012 | Computers & Internet
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Cd rom drawer on dell laptop won't open
hello, have you tried going into "My Computer" then right clicking on cd drive and click "Eject"? if not, try that.
if you have then take a thin paper clip open up one side of it so its straight.
After you have paper clip straighten up look carefully around the cd rom's eject button and you will notice a tiny hole.
Take the paper clip and keeping it straight slowly and gently insert in the hole and soon you will feel little resistance push it a little bit more and that should eject your CD rom.
if it opens up leave the cd rom open and reboot your laptop once and see if your drive now work normally and ejects the way it should?
hope this helps, post back if you have issues.
Kind regards,
Amar Sondhi
Jan 22, 2010 | Dell Inspiron™ 600M PC Notebook
My CD rom drive won't eject the cd on my Dell Studio Laptop. I press the eject button on the comp, and the click eject on the cd screen, and it makes a noise but nothing comes out.
You may have a cd jammed in your drive. Switch the computer off and on the front of the CD rom drive is a small hole, if you push a straightened paper clip quite hard into this hole it will open the drawer.
Nov 07, 2009 | Dell (0F146) Internal DVD Drive
CD won't eject. I have tried the button on the drive and clicking the eject through the software. The light lights up and there is a whirring sound, but then nothing.
your cd rom tray is stuck inside may be due to a hardware error please take a paper clip and make it straight now insert this clip in a small hole located at the front panel of your cd rom drive..apply some pressure and the tray will be ejected/..
Thnx and i hope this helps
Please rate this solution
Jul 16, 2009 | Dell (0F146) Internal DVD Drive
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Problem with cd-r/dvd rom
does the light come on on the drive ? have you tried straightening a paper clip an putting it in to the little hole to push the draw open this may make it work if its stuck or try right clicking the drive in explorer and choosing eject from there
good luck
Jan 23, 2008 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
HP Pavilion Ze4900 Notebook Logo
141 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
