Question about GE Profile Spectra JGBP79 Gas Kitchen Range
Oven is not working
I used my oven yesterday and it was fine this morning the stove and the broiler work and the warmer also the clock is ok too it is just the oven that wont heat up
  • jan_boiteaux Oct 05, 2008
    Everything on the stovetop works fine but the oven will not heat up. Anyone know why?
The glowbar or igniter bulb is burnet out
Posted on Apr 11, 2008
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts -
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
Morning I have a Stoves EFA600H electric oven and whilst the hob still works ok the clock and oven do not. The clock did start flashing last week and now has gone completely - any...
The electronic clock/timer must work correctly and be in manual mode for the oven to work. It sounds as if you need to replace the electronic clock. If you do not need the clock function it is fairly easy to bypass the clock altogether and the oven will work no problem.
Feb 23, 2011 | Stoves Ovens
My gas oven, Super Capacity 465 the oven nor broiler light. The stove top works fine.
Hello there
Please read the entire solution i have provided below ok
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician.
Sep 28, 2010 | Whirlpool GS460 Gas Kitchen Range
Oven doesn't work - broiler, clock timer does
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jun 05, 2010 | GE Profile Spectra JGBP79 Gas Kitchen...
Top broiler element works sometimes but not often
Sounds like an iffy clock control. You could try replacing it, but it ain't cheap.
May 21, 2010 | Whirlpool RF364 Electric Kitchen Range
Kenmore electric oven will not heat, broiler and stove work fine
I also have the exact same problem, is ther a possible fix-it-yourself solution for this???????????? if not what should a repair cost?????
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
128 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
