Question about Zebra S4M Thermal Label Printer
Zebra s4m printer can't set up the height to be .375 it goes to .37 are these labels just not compatible?
    Problem Solver:
  • 15 Answers
As long as your printer front panel setup is set to AT LEAST your label height, you should be fine. You set up your EXACT height in your label software page layout.
Set up the printer for 1 inch height, and the gap sensor will work fine. Just make sure your printer driver is also set up for 1 inch, and make your label creator software page layout exact.
Posted on Jun 07, 2010
Restore defaults
hold pause+feed buttons while turning on the printer. release after 10secs.
Oct 01, 2013 | Zebra S4M Thermal Label Printer
S4m quick books
change the default orientation setting in printer properties.
May 10, 2013 | Zebra S4M Thermal Label Printer
Is there a way to change the setting on the Zebra S4M to rotate the print 180 degrees to match our labels?
No. The change must be made in the software that you are creating the label design in. Let me know if this helps!
Jun 21, 2011 | Zebra S4M Thermal Label Printer
Is it possible to import data from excel into the labelprinter Zebra S4M?
You can print a text from XL, but you owuld have to use a page set up that is the same as the label size, through a Zebra or Seagull driver.
Feb 10, 2011 | Zebra S4M Thermal Label Printer
Zebra S4M printer Alert Message: Ribbon out I'm using a thermal paper. There is no print method mode.
In the software printer driver- set it to direct thermal or no ribbon. It will override the printer setting.
Dec 09, 2010 | Zebra S4M Thermal Label Printer
Settings seem correct, but labels will print on 2 labels, or skip labels. Zebra s4m
The printer is not calibrated to the media length. You need to perfrom a calibration with the labels loaded. This is in the users manual on how to do it. The printer should be set to automatically do this when powered up.
Oct 20, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M label printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
Jammed S4M Printer
Do what the other guys did and cut the labels and pull it with a set of plyers. Does not seem to be a better way
May 27, 2009 | Zebra S4M Thermal Label Printer
S4M doesn´t print
The S4M comes with either EPL or ZPL programming language installed. (installed at factory) The S600 is a ZPL only printer. Check that you have correctly specified the S4M as a ZPL printer. Print a config label to check. If it is set as an EPL printer contact your supplier and ask him to download the correct programming language. It should only take a competent engineer about ten minutes (If he knows what he is doing)
Jan 20, 2009 | Zebra S4M Thermal Label Printer
Printing every third labels ---> not every one:(
Sounds like the label height is set too high. Go into Printer Preferences in Windows and change the height dimension to match the size of the label you are using.
May 08, 2008 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
259 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
