Question about Hagen Power Glo Mini Light Bulb
I have a Bell&Howell cube slide projector model 9810 with stripped gears on slide advance. Is this plastic gear available as a spare part? Denny Trnka
4 Suggested Answers
SOURCE: I have an old Bell & Howell projector and I
These guys obviously have something to sell. PLEASE DON'T THROW YOUR MOVIE PROJECTORS AWAY. DVD-R has a useful life of about 5 years at best.
To answer the question posted: As the bulb ages, the extreme heat causes a bulge in the glass and that's why the bulb won't slide down. The only option is to tap the top of the bulb with a screwdriver (or similar instrument) and shatter it--then unscrew the housing and let the mess fall out. Be sure to protect yourself from shards! Once you clean up the mess you can install a new bulb (DAR, I believe).
Once you see the rich gradations color of real film (even 50 year old film), you'll be hooked!
Posted on Jan 27, 2010
farmerbear
  • 490 Answers
SOURCE: I have an 8mm Bell and Howell projector that seems
There is a worn belt in there, sounds like to me. And, yes, cleaning is always good. Remember not to touch the lens with your fingers as this will lead to early bulb failure. farmerbear at FixYa.com
Posted on Sep 29, 2010
SOURCE: I have a bell and
Push down the clear plastic cover through which you can see the pronged wheel. That pushes the film against the prongs, and it should then load
Posted on Jan 03, 2011
Can I buy a new Bell & Howell Slide Cube Projector?
No! They are no longer made due to the computer generation and slide presentations are usually made with laptops now. You should be able to find one good used one on eBay if interested find your model # of projector and look it up on ebay. They are usually in good condition but make sure lamp works on the one you are buying as these are expensive to replace. Rich
Dec 20, 2014 | Bell & Howell Vintage Slide Cube Projector...
Bell & Howell slide projector 454
go on line to bell & howell site and down load service manual or operators manual.
Jun 09, 2013 | Office Equipment & Supplies
Need bulb DFC for Bell & Howell Model 256
what kind of lamp do I need for a Bell & Howell projector model 256?
I bought this projector but doesn't come with the bulb.
Aug 19, 2012 | Hagen Power Glo Mini Light Bulb
Plastic worm gear replacement for Model 550 Bell and Howell Filmosound 16mm projector --"Specialists"
The worm gear is part number 012666 and can be purchased brand new from Larry Urbanski at Urbanski Film in Illinois.
Jul 22, 2011 | Cameras
How to replace a worm gear on a Bell & Howell model 2585 16mm film projector.
Replacing the worm gear on a Bell & Howell 16mm film projector is a very long and involved process requiring a complete teardown. It is similar to replacing a blown head gasket in an automobile engine. The worm gear is the heart of the mechanism and takes a lot of time consuming labor just to get to it. In the process you lose a bunch of critical adjustments which require resetting with special Bell & Howell tools/jigs/gauges. Many of these projectors are at least 30 to 40 years old and will also require re-lubrication.
The gear itself costs around $30-ish and takes 3 to 8 hours of labor to replace. Richard Patchett in Michigan and International Cinema Equipment in Miami, Florida does the worm gear replacement.
May 04, 2011 | Video Game Consoles & Games
I have Bell&Howell 16mm film projector. Clean and has worked with no problems. Turned down sound during silent movie. Played next reel with sound but could not get sound. Then the reels stopped...
If you don't know how to service this type of machine, I would contact a Bell & Howell dealer and get it repaired/serviced. It possibly needs the magnetic head cleaning.
Apr 17, 2011 | Televison & Video
My son just purchased a Bell & Howell 2575C 16mm projector which seems in good working order; however, we cannot figure out how to turn on the light (the bulb appears to be fine)...we've threaded film,...
Chances are that if everything else seems fine and is coming on then most likely you have a bad bulb or it could be loose,make sure its fitted into the bulb holder assy good and snug,dont force it or you will break it at the base.Go to google and google your model number for the bell and howell projector and find out whats available and pricing.A middle of the road or average bulb should be suffice for what your doing.
Feb 09, 2011 | Bell & Howell Cameras
I bought a bell & howell movie projector, need parts
Well Bell and Howell have a website, so i would suggest rtying them first to see where the distributors local to you are. Or you can contact a camera store and see if they will accept it as a repair or supply the parts
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Cameras
My Bell & Howell cube slide projector has a strpped drive gear that rotates the slide tray. Is there any one that can help regarding parts or places that might do a repair?
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=360183793446
Bell & Howell Cube Slide Projector Gear, New Item condition: New Quantity: More than 10 available Price: US $15.00 Approximately C $15.54 Buy It NowBuy It Now
This is the gear that goes bad on Bell and Howell cube type slide projectors. If you have one of these projectors you can pretty much expect the gear in your machine to go bad. The original gears were made out of an inferior material that was too soft. New old stock gears would be made of the same material and although they have never been used they most likely will fail right away since they are made of the same inferior materal. They were made soft to reduce the mechanical noise when the gear runs. This was told to me by the person who designed them at Bell & Howell. These new replacement gears are made out of Delrin, an excellent material for gears. Delrin is sometimes used to make gears that are normally made of metal. Don’t miss your opportunity to finally fix that old projector or get a spare gear for your working machine while they are available.
Detailed installation instructions will be included with every gear.
Feb 08, 2010 | Cameras
I have a Bell & Howell slide cube projector that has been packed away for many years. The rotating disk will not advance the slides for viewing. The disk seems stuck. I have been unable to find anyone...
I occassionaly experience the same problem. I don't know why it occurs, however; here's what I do to get the projector moving again: 1) Face the right side of the projector wherein the lens will be pointing to your right. on the middle top of the projector edge closest to you you will see a top access tab. 2) Move and hold the tab to the left and lift open the top of the projector. 3) On the edge of the rotating tray at about the 5:00 position (my guess as I'm not at the projector now) you will slot in the circular plate aligned with another slot on the fixed casing. Inside this sloted area there is a metal pieve that spans the slot across the two surfaces. 3) Take a screw driver and giggle this metal peice, pressing dow and releasing, and / or in and out, while pressing the slide advance advance forward and back. I found no ryhme or reason to this or that it readilly works after so many jiggles, however; it alsways does usually after anywherefrom a few seconds to a minute or two. This isn't a fix but a temporary workaround. I'm in the process of sulling my thousands of slide to be digitized, after which I will no longer need this wonderful legacy machine. Hope this helps. Regards,
al1@copper.net
Jan 24, 2010 | Cameras
Hagen Power Glo Mini Light Bulb Logo
128 people viewed this question
Top Hagen Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hagen Garden Expert? Answer questions, earn points and help others
