Question about Canon FAXPHONE L170 Plain Paper Laser
I can not turn off the Memory Lock. I've tried to follow the directions in tha manuel on 9-3 and 9-4 but I have had no luck with this... Please help!!!
MEMORY ERROR on the screen even
Keep in mind tha compabilitie memory card for this camera. Try formating your memory card.
Aug 22, 2012 | Canon PowerShot SD4500 IS Digital Camera
I have to type holding down the function key. it is NOT a problem with the numlock, i've tried that. all the main information I can give you is that above the keyboard (where the caps lock is...
Well, a light with a 9 digit means exactly that you have turned NumLock permanently on.
You have to press NumLk holding the Fn or Shift or Alt key to turn it off (try all three until the [9] goes off).
If this fails, consult this page:
http://www.ehow.com/how_5893662_turn-off-numlock-laptop.html
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 29, 2011 | Dell Computers & Internet
Need code for trutech dvd player
There is not a direct code listed in the manual but you can try doing a search for the code by doing the following sequence.
  1. Turn the power on to the DVD player.
  2. Press and release the DVD button on the remote.
  3. Press and hold SET until the LED (red light) blinks twice,
    then release SET.
  4. Enter 9 - 9 - 1.The LED will blink twice.
  5. Aim the remote control at the DVD and slowly alternate
    between pressing POWER and DVD. Stop when the DVD turns off.
  6. Press and release SET to lock in the code. If successful the LED will flash twice.
This should help you find the code. Just don't get in too big of a hurry alternating the POWER and DVD buttons or you could accidentally pass the code and have to start all over.
Good luck,
Robert
Feb 26, 2011 | One For All URC-3021 Remote Control
I have a new memory card for my kodak easyshare cx6330 camera.when I turn the camera on the message on the screen says memory card requires formatting. when I attempt to format it it says formatting for...
The CX6330 works with MMC and SD cards. If your new memory card is larger than 2GB then it's actually an SDHC card and will not work in the CX6330.
You can view/download the manual at the manufacturer's web site at
http://support.en.kodak.com/app/answers/detail/a_id/18498/kw/cx6330
Jan 04, 2011 | Kodak Cameras
My smadl phone has become useless after i put it in flight mode.please help me remove the flight mode so that i can use my phone.
If you do not have your manuel handy or it does not have the information needed to re-set the mode, try asking an employee of almost any cell service provider; they are usually happy to help, as it makes their day go by more quickly, they are helping a potential future customer and they also have access to manuels for almost all cell phones (even if they need to jump online). Without having your phone in front of me, the only other thing I could suggest is to find the manufaturers web site, then find your phone model & check for instructions/manuel info direct.
There is also this; in your main menu, you should have a settings choice; follow it past bluetooth & security to the SETUP/OTHER or something that looks similar (ie, not display, sounds location, etc). This should be where he TTY & Airplane mode are; enter OK on that & follow the requests or directions, as this may lead you directly out & re-set you out of the Airplane mode.
Good luck, & have a wonderful, safe holiday season.
Nov 17, 2010 | Cell Phones
Dell Lat d600 laptop---9-Lock
Change the Location of the main memory , If it works then you have problems with the slot.
If it deosn't work then change your Memory!
Nov 03, 2009 | Computers & Internet
Vostro 1510
Possible memory issue. Try Reseating your memory card on the system, it would be helpful.
Sep 06, 2008 | Dell Vostro 1500 Notebook
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Memory Card Protected
On the memory card itself there is grey slider. Make sure it is NOT in the lock position.
Jan 26, 2007 | Panasonic Lumix DMC-LC70 Digital Camera
Canon FAXPHONE L170 Plain Paper Laser Logo
19 people viewed this question
old marine
old marine
