Question about Boating
Want to start it out of the water, but ''ear-muffs'' do not get water out of the ''tell tail'' when hase is running into ear muffs/water intake. does motor need to be running to get water from intake to ''tell tail''? Is cooling system clogged?
Yes the motor must be running for tell tail to work.
Posted on Nov 13, 2009
How to water flush a mercury 4hp 2 stroke
You will need the flush-kit adapter also known as ear muffs. You connect your garden hose to the ear muffs, then start the motor. It is a good idea to first prime the motor befor trying to start the motor. Then turn the water on right after the motor starts.
Nov 01, 2016 | Boating
I have a YAMAHA 225 FOUR STROKE OUTBOARD. WATER PUMPS OUT TELLTALE WHEN ENGINE IS RUNNING, BUT WHEN CONNECTED TO A HOSE FOR FLUSH OUT NO WATER COMES OUT THE TELLTALE.
If you telltale operates under normal conditions, I take it you have the tap on, muffs over the inlet
and engine running, have you checked the muffs are on the correct way round, is water passing through the inlet vanes, is it passing through the hose pipe? If you have checked these and all is good, and still no tell tale then run the engine in a drum filled with water. If still nothing or the telltale is weak then your impeller is on the way out.
Sep 15, 2015 | Yamaha Motorcycles
Will a bad upper intake manifold gasket on a 97
sounds more like a blown head gasget a compression test will tell you for sure
Sep 25, 2014 | Cars & Trucks
Do I need to protect my ears when the weather is very cold?
Yes, ears are very sensitive parts of the body and can be vulnerable to frost bit in very cold weather. Use ear muffs or a hat to protect them.
Feb 20, 2013 | Health & Beauty
Water is not going through the engine when operating in the sea. On land with muffs on and hose pipe attached water is forced through the engine o.k.
Are you sure that your impeller intake is submerged when you are on the boat? If it works with muffs, it should work in the water too, unless you don't have your lower unit deep enough.
Dec 27, 2010 | Boating
I just bought a Yamaha 60 HP engine and was told that I need to clean the engine out with a garden hose once I have run it in the ocean. How do I do this?
You will need what is called "ear muffs"or flush kit to fit over the water intake holes so you can attach the hose, or you will need a large bucket filled with fresh water that the engine leg will fit into and give the engine a run for a few minutes
Aug 22, 2010 | Yamaha Sport & Outdoor - Others
Just bought a used boat, 1966 sportscraft with an evinrude 2 stroke motor, don't know how to test the motor without going into the water. don't know much about boats
Hi. If you just want to run the motor then you can do it in you driveway. Go to a sports store with boating equipment and ask for "Muffs" to run your boat motor out of water. You can see a pictures of outboard motor muffs on google images:
http://www.google.com/images?hl=en&source=imghp&q=muffs+for+outboard&gbv=2&aq=f&aqi=&aql=&oq=&gs_rfai=
Take the muffs and place them over the water intakes located above the propeller (look like vents on each side). Hook a garden hose up the muffs and start water flow. Make sure nothing is near the propeller. Make sure to pump the bulb in the fuel line to the motor until it stiffens. Crank the motor. When the motor starts, you should see water start to flow out of the back of the motor near the cover and out of the center of the propeller with the exhaust. You must keep water flow to the motor using the muffs while it is running or it will burn up.
Apr 27, 2010 | Boating
15 hp outboard 2 stroke running with water muffs on,there is no water coming out of the **** tube? Check the impeller? where is it? Just bought the the motor.
Impeller is at the bottom in the housing. it may take a few mins for the water to come out of the tell tale hole. Ensure that your muffs are on properly and wait for a bit. Also insure that the hole is not plugged.
Sep 07, 2009 | Boating
15hp push idle in motor shuts off
First, always have the motor in water or with a hose and muffs when you run it. It is simple to fix if all the parts are there. Let me put it this way. If you know where the air mixture adjustment is on the carburetor you turn this screw until the engine speeds up at idle to a maximum rpm, then back in 1/4 turn. Adjust throttle stop screws to achieve a minimum base idle. If this seems complicated, take it to an outboard place or lawnmower shop(if you have a hose and muffs). Its a 15 minute job and will last until its changed.
Jun 13, 2009 | Boating
Boating Logo
65 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
