Question about Samsung DVD-H1080R DVD Player
Samsung H1080R plays wrong region
My samsung dvd player, H1080R, is supposed to be region 2, but it only plays region 1!! any ideas on how to change the region code? keep in mind that the remote does not have numbers to press!
Same problem, no support from Samsung Netherlands.
No solution yet, sorry
Posted on Jan 07, 2010
My Samsung smart tv & my dvd/bluray player recorder I bought at same time. Haven't had blurays til now & wont play at all. Rental ones did now I've bought my own & they don't play!Not tech minded.HELP
Each DVD player is assigned a code for the region in which it's sold. For example USA/Canada are Region 1 players. DVD players will refuse to play discs not coded for its specific region. In effect, this means that a DVD purchased in one country is normally unreadable on a DVD player bought in another region.
If your rental DVDs work in the player then there is nothing wrong with your DVD player. If you have purchased DVDs that do not work the problem is with the DVDs you have, not with the DVD player.
Jun 04, 2016 | Samsung Televison & Video
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
Nov 07, 2009 | Samsung DVD-V85K DVD Player / VCR Combo
I have a samsung dvd r 120, two dvd's i rented
Is it possible that the region codes of the DVD player and the DVD's are different?
Sep 10, 2009 | Samsung DVDR120 DVD Recorder
I have bought samsung dvd player h1080 and it seems that it is region 1 how can i make it region 2. thanks
After searching the best known region hack databases I have found one process for your make and model. I can not assure you that it will work 100% but it's the only known process.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
I hope this works for you, thank you for choosing Fixya!
Aug 29, 2009 | Samsung DVD-H1080 DVD Player
How to unlock the samsung dvd h1080?
SAMSUNG DVD-H1080 This worked for me:
Turn on the DVD without disc in the tray
Press repeat (not repeat a-b)
Press fast forward (>> not >>l)
Press rewind (<< not l<< )
Press up
Press down
'0' appears in top right corner
turn off then back on.
Aug 03, 2009 | Samsung DVD-H1080 DVD Player
Unknown disk -samsung HT-x30 DVD Player
FIxed this by downloading the firmware upgrade from samsung and applying it.
Dec 17, 2008 | Samsung Integrated DVD Player and Home...
Free region code for samsung dvd HT-
Multiregion samsung
It is suppose to work on most samsung dvd players
Use by your own risk
Turn on
Press repeat or subtitle button
  • for Region 1 press 2, 9, 3, 3 and 4
  • for Region 2 press 3, 8, 7, 6 and 7
  • for Region 3 press 5, 6, 7, 3 and 2
  • for Region 4 press 7, 6, 8, 8 and 4
  • for Region 5 press 5, 3, 8, 1 and 4
  • for Region 6 press 2, 4, 4, 6 and 2
Press 9
Turn off and on again
Oct 09, 2008 | Samsung DVD-V90K Multisystem DVD/VCR
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Samsung code
1. Cold start the player, by holding down the PLAY and STOP buttons on the player.
2. You should see a set of language options. Release the PLAY and STOP buttons.
3. Select your language.
4. Press REPEAT (not the repeat A-B button) then the following codes for the required region the player is already set to (region you bought the player in):
5. A code will appear, indicating the region setting of your player.
6. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
7. Press OPEN on the Player to open the disc tray.
8. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified.
Jul 05, 2008 | Samsung DVD-P244 DVD Player
Incorrect region codde
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
Apr 27, 2007 | Philips DVD 622 DVD Player
Samsung DVD-H1080R DVD Player Logo
548 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
