Question about Exercise & Fitness
Treadmill won't turn on after not being used for 6 months
We moved from Michigan to Texas. After 6 months of sitting in my garage, I plugged in my treadmill and it does not turn on. Is there a switch I am missing besides the off/on switch under the display area? I have a Profrom 770 EKG treadmill.
    Sniper:
  • 103 Answers
The only on/off switch on that model is located beside the power cord where it enters the lower body area.
Posted on Nov 13, 2009
I have a reconditioned Precor C954. It has been sitting unused for at least two years. I plugged it in and the fan on the motor turns on, however the console does not light up. Perhaps a fuse issue?
You can start with checking the fuse, but I would also verify the correct voltage is making it to the lower board. Start at the wall outlet and follow the power through the cord and through the on/off circuit breaker. If you are getting power to the lower board and not to the console up top, it could be one of a few things. It could be the lower board, the wiring from the lower board going to the console, or the console itself. You will need a multimeter in order to do the proper troubleshooting. I will attach a link where you can view the service manual for your machine. There will also be a link to a video on using a multimeter.
http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Generic%20Service%20Manuals/COMMERCIAL%20TREADMILL%20GENERIC.pdf
Video about Multimeter Testing
Jan 19, 2013 | Life Fitness Treadmill Precor C954 (Used)
Proform elliptical 820 left sitting for months in florida room but worked fine before, batteries replaced, now the rpm's don't show and programs won't start. i have a feint memory of havin
1) replace by new batteries with the same type fulll charge, with the same mark, with the same polarity
2) clean the contacts batteries with contacts cleaner for a dirty, corrosion, etc
3) adjust the REED switch, test it, clean it, and tight any plug or connector.
4) tight the ribbon cables for keypads good connection.
Try again.
Of course you must know the power cord is o.k the c. breaker you must reset and some fuse is o.k o replace see the b.diagram
God bless you
Nov 19, 2012 | Exercise & Fitness
What could it mean if the treadmill just stops, but the board is still lit up? The belt won't move even when I turn the treadmill off and turn it back on. The numbers on the board light up, but...
Dear Sir:
I will help you, inmediately.:
Try it with this step:
When machine is Stopped with various months, the dust+ corrosion in the electronic system can be affected.do it the following :
    • 1
Someconsoles require batteries. Check to see if this is the problem. If the consoledoes not use batteries, move on to Step 2.
    • 2
Removethe key from the console.
    • 3
Unplug the power cord.
    • 4
Removethe screws from the console hood and remove the hood.
    • 5
Turnthe pulley until the reed switch and magnet are aligned with a 1/8-inch gapbetween reed switch and pulley.
    • 6
Replace the hood.
    • 7
Plugin the power cord.
    • 8
Reinsertthe key into the console.
    • 9
Runthe treadmill to check for a correct speed reading. This may take a fewminutes. Check this, and contact me, if you need some additional help. blessing , sincerely. E.CUADRA MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Reebok Exercise & Fitness
The bikes do not shift the bike has been sitting in a garage for about 6 months.
Being a complex mechanism it would require a bit more of a visual analysis to identiy WHY it won't shift.
Get on a search engine and read up on "how bicycles shift" to get a better handle on the problem.
"how to..." just about anything also leads to instant answers.
http://www.parktool.com/blog/repair-help
Aug 17, 2011 | Cycling
Machine is plugged in but won't turn on. We haven't used it in about 6 months. Please advise as to what we can do. Other electrical appliances work using outlet that we have the treadmill plugged into.
Check the circuit breaker located beside the power cord. Be sure that it has not tripped. Snap it back into place if tripped.
Confirm that the on/off switch is switched on.
Insert the safety key in the slot on the front of the console. The console should light up.
If nothing lights up, I would suspect the power supply PCB, part #180635.
Dec 18, 2010 | Proform LX660 Treadmill Walking Belt
Breaker keeps tripping when in use at any speed even when my son uses it and he weights less than 100 lbs.
1. Make sure you are using a surge supressor, but this likely isn't the problem.
2. Make sure you aren't plugged in to a GFCI outlet such as those in a garage, basement or bathroom. (If this fixes your problem, you should still follow steps 1 and 3)
3. Make sure you are lubricating the walking belt every 6 months with a 100% silicone, treadmill lubricant,(this is important)
Oct 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
320 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
