Question about Xerox Phaser 6110MFP/X Laser Printer
Replace transfer belt won't scan or print
    Master:
  • Xerox Master
  • 956 Answers
Unless you are a DIY er. Callin supplier or repair engineer.
Remember check to make sure what their charges are like set price callout charge?
Are you due to replace???
Posted on Nov 12, 2009
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
How i replace ETB for hp cp4025
Replacing the Transfer Belt (ITB, Transfer Kit) HP Color LaserJet CP4525 CM4530
1. Open the printer's right side door.
2. Use the blue lever (see callout 1 in picture below) to lower the secondary transfer assembly.
3. Grasp the small handles on the transfer belt assembly (circled in blue in picture below), and begin gently pulling the assembly out towards you, until a set of 2 larger handles pop free on the sides of the transfer belt assembly.
4. Now grasp the larger handles on the transfer belt assembly, and continue pulling the transfer belt straight out of the printer until it is completely removed.
5. Avoid touching the surface of the new transfer belt. Install in reverse order, sliding it securely into the machine.
6. After replacing the Transfer Belt, it's a good idea to perform a Full Calibration (or even several Full Calibrations in a row, if you are having print quality issues). Full Calibrations help with print quality by aligning the color tones, the drums, and the color plane. Each Full Calibration takes about 4 minutes. To perform a Full Calibration: Press MENU to enter the menus. Press Down Arrow to highlight CONFIGURE DEVICE. Press Checkmark to select CONFIGURE DEVICE. Press Down Arrow to highlight PRINT QUALITY. Press Checkmark to select PRINT QUALITY. Press Down Arrow to highlight FULL CALIBRATE NOW. Press Checkmark to select FULL CALIBRATE NOW. Wait for the printer to calibrate (usually takes 4 minutes or so), and then print a test page. If print quality still needs improvement, repeat the Calibration. If multiple Calibrations don't help, some of the toner cartridges may need replacement.
5e5fcf65-5757-40c3-a110-1a2864982d2e.jpg 554a3a0e-c038-46ec-983d-7467c3deeccf.jpg 7883eb6b-6a29-43fd-b69a-0ff825f60373.jpg bb2de9b0-8f0f-4f6a-a69f-ed1001f8bd09.jpg
Jul 15, 2014 | HP Laserjet Cp2025n Printer
Maintenance TK1
TK1 Primary transfer unit counter has reached preset value or number.
To correct error, replace primary transfer belt/rollers. Enter calibration/diagnostic mode and reset counter.
Jan 15, 2014 | Sharp Mx-2310u Color Copy/print/scan
I have used Mx-2310U (copier, scan, print). It is not work now. I see error code L4-06. So. I thought out the Manual, but I don't know solution of this problem. I am very busy. Please answer as soon as...
Dirty or broken sensors in the inside back of your machine that detect movement of your mylar transfer belt. A portion of the belt swings up and down for color printing. Or your belt unit may be broken or not installed properly
Oct 24, 2013 | Sharp Mx-2310u Color Copy/print/scan
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
Replace transfer belt message
replced the transfer belt but still getting the replace transfer belt message?
May 27, 2010 | Samsung CLP 300 Laser Printer
Hp 2600 n
OK. This sounds like a bad transfer belt. Does this printer have a lot of use? Do you think you have like 75,000-100,000 copies on it? If so it is very likely.
If you are SURE the fading is on ALL cartridges, then it has to be the transfer belt assembly. (that wide film part on the inside of the front door). You can buy this part, and instructions to replace it are very straightforward. Its not just the film you replace, its a module.
One last hing, if it is only happening on ONE cartridge, then all you have is a bad cartridge. All 4 = transfer belt.
Apr 20, 2008 | HP Color LaserJet 2600n Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Xerox Phaser 6110MFP/X Laser Printer Logo
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
