Question about Health & Beauty
Is there a way to size a stainless steel wedding ring
  • Charles Williams Nov 12, 2009
    Thank you for your help I'll check with some jewelers
  • 4,102 Answers
Hi, what do you mean by size if you mean you need to find out what size it is then you only need to take it into any jewelers and they will put it onto a metal rod and give you the exact size they wont charge for this, this would be the best way.
You could also buy one from an auction site or jewelery web site they usually send you them for free from jewelers site so you could try their.
If how ever you mean change the size then the only way this could be done is at a jewelers if it was to be made smaller then im sure a jewelers would do this for you for a small fee, if how ever you want it made bigger then a jeweler can make it a certain amount bigger but if it needed to be much bigger then this could be a problem as jewelers only deal with precious metals so im not sure you would find anywhere that would offer this service, you could look online maybe even a jeweler could do this im not to sure but it wouldnt cost you nothing to ask at a jewelers so that is what i would suggest.
Let me know if i have got your question wrong then i will offer you the best help i can.
Let me know how you get on or if you need further assistance ok.
Many thanks for using fixya.com
Posted on Nov 12, 2009
  • paul proctor Nov 12, 2009
    hi, no problem mate glad to offer some advice,
    Thanks again for using fixya.com
    Tell your friends and family about the site the more the merrier
What does TK316 mean when stamped inside of a ring?
It means high-quality stainless steel, and it's durable and corrosion resistant. AlamodeOnline has this the trademark TK316 jewelry-grade on the stainless steel products compared to other normal stainless steel jewelry product on the market. After years of wear and tear, they will still look fantastic and brilliant!
Oct 04, 2016 | Cars & Trucks
Tip
Stainless Steel Flanges Manufacturers
Stainless steel flanges is an iron based metal. Stainless steel flanges are normally chosen for their high resistance to corrosion and its high-temperature strength. Although they are chosen for their resistance to corrosion does not mean they are immune to it. Stainless steel flanges also show other characteristics like ductility and toughness which should be taken into consideration. Different types of stainless steels show considerable variations depending on a combination of its chemical composition and the aggressiveness of the environment.We manufacture flanges from sizes ½" to 36? and in dimensions from 15mm to 600mm. Instinox being Stainless Steel Flanges Manufacturers provides you with best quality & services
on Jun 16, 2016 | Miscellaneous
Is a ring marked 14k A/ a genuine gold ring?
It\'s illegal for a jeweler to mark a ring as 14K unless it\'s actually gold, and it\'s not uncommon to set a CZ in real gold. The only way to truly know is to get it tested, but I would bet that it is really gold.
Oct 13, 2014 | Reeve and Knight 14k Yellow Gold Round &...
I'm looking for FrancisFrancis X1 TRIO - Replacement 'O' Ring
I bought an O ring kit on ebay - measure the size of the O ring and get a kit that contains this size. The kit contained 500 O rings for £10 and you'll only use 1.
Nov 30, 2012 | FrancisFrancis! X1 - Stainless Steel...
Does the chimney need a stainless steel liner
If the fuel is either wood (or any wood products) or oil it is required to have a stainless steel liner. Gas burning appliances need an Aluminum liner. Make sure it is sized correctly and not over sized.
Feb 17, 2011 | Heating & Cooling
What is the main difference between pipe threads and bolt thread?
pipe threads taper. measurements are different.names are drefferent.pipes are called ips or iron pipe size.bolts are by size and noumber of thread per inch or mm
Dec 06, 2010 | Computers & Internet
Is there a replacement door for a Kitchenaid kudi01tjwh0 dishwasher made of stainless steel? Maybe another model with the same size/layout of the door?
Applianceart.com has stainless steel options for door panels as well as a faux stainless steel that was on HGTV. I'm not sure if the panels they have would fit your model, but their rolls of stainless would definitely help.
Nov 24, 2009 | KitchenAid 24 in. KUDI01TJ - Multiple...
I am looking for a stainless steel replacement panel for a Frigidaire fdbc45bab1 dishwasher.
Go to www.applianceart.com. Cheapest options. Have real stainless and faux stainless and will make sure you get the right size.
Nov 23, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
The stainless steel rings on my cooktop are already getting burn stains. How do I clean them without discoloring the rings?
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jun 17, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Want to replace dishwasher panel with stainless steel
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Health & Beauty Logo
18 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
