Question about Dimplex CS3311 Compact Heater
The fan cuts off almost immediately after being
Heater is one year old. The fan cuts off almost immediately after being turned on. Any suggestions?
    Scholar:
  • 108 Answers
You could have a bad Heat sensing switch...or the wiring itself could be a bad connection........UNPLUG the heater first.....follow the wires coming from the fan and they will lead to the switcvh that brings the fan on...ensure the connections look ok......If they are fine install a "jumper" wire across the 2 terminals and plug the unit back in the fan should run continuously....then you know the switch is no good....if the wires go to a Rheostat (adjustable speed control) ensure that the dial is on....becareful the jumper wire doesn't touch anything...and test it briefly...you will be able to tell if the fan is ok...you may also be able to simply marette the wires going to the switch together which is the same as a jumper wire...if you're unfamiliar with Electrical or anything I'm saying I suggest you call a Qualified Technician
Posted on Nov 13, 2009
The fan motor is bad. without the fan running the thermostat shuts off quickly. if you pay attention the fan will barely run or not at all. replace the fan motor and it will run fine.
Posted on Jan 25, 2010
Fan will not cut off
Janet, the problem most likely is not in the thermostat. It is probably the fan relay on the circuit board in the furnace. Some furnaces have an individual fan control board, some furnaces have all the controls integrated within one control board. If your furnace is 20 years old or older, it could be the fan/limit control because at that time all furnaces did not come with a control board. If it is much older than 20 years, it is much more likely a stuck fan/limit.
Apr 12, 2015 | Honeywell Programmable Thermostat Heater
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Suddenly there are loud weird noices coming from
check evaporator fan for free operation and defrost heater for proper operation if no operation it will build up ice and hit fan blades!!! :)
Jul 08, 2009 | Refrigerators
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Duracraft Heat Giant Electric Heater Model CZ-2104
I have the same heater,04-08-97, have had problems with fan motor bearings, does the heater,Humm, when turn it on, this indicates loose motor bearing fan side.If so,unless you can find a replacement motor,as I have tried,your heater is on the way to the scrap yard.If you can find a replacement motor, please post it.
Jan 16, 2008 | Heating & Cooling
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Dimplex CS3311 Compact Heater Logo
298 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
