Question about Sony Playstation 3 (PS3) Console
1080p 480p on ps3 some games are in 1080p 1080i 720p and 480p when games like call of duty 3 are played it plays in 720p the game supports 1080i but it wont play that way am i doing something wrong
  • 182 Answers
If you hold down the power button when you turn it on for more than 4 seconds it runs the display setings and puts it in the best possible option
Posted on Jan 08, 2008
Won't display games in 1080p on PS3
Being Sharp authorized dealer for past 11 yrs. it is one of two problems. 1- Get updated software from Sharp Online. 2- The T-con or otherwise known as controller board has a defect. This board controls all resolution lines and formats down to pixels on your screen. Let me tell you we have a box with several hundred of these boards with various defects all associated to picture and resolution problems. let me know what you find.... EXPERT-TECH@LIVE.COM
Mar 17, 2014 | Video Game Consoles & Games
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
MY PS3 DOES NOT SEEM TO BE WORK WITH THE HIGH DEFINITON CABLE IT CAME ON FORA FEW SECONDS THEN SCREEN COMES UP WITH NO SIGNAL????
This usually happens when you first buy your ps3 and try to use the HDMI connection immediately. The problem is that the ps3's default output resolution is set to 480i out of the box, and when you try to use an HDMI connection first, HDMI can't do that resolution. HDMI only does 480p, 720p 1080i and 1080p.
See :)
This also happens if you move your ps3 a lot. As it is, HDTV's are either 1080p (full HD) or 720p (including 1080i). If, for example, your tv is 1080p, when you set your display settings in the ps3 menu, it will set your XMB, or ps3 main menu to the max resolution of your tv, 1080p in this case. The resolution will automatically adjust when you start a game, and that game has a native resolution output. That's why, most of the time, games will play in 720p, because that's there native, or original, resolution. This is also the reason why sometimes people have no display on there TV, or a black screen, and when they play a game, that will actually display. That's because your tv can ACCEPT that resolution of that game.
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
HDMI-can't get tv to stay 1080i
This is natural, the PS3 does not stretch the signal like the Xbox does so games play at there native resolution (720p) there is nothing wrong with your TV or your PS3 and you would not see any difference in the games graphics if it was in 1080i. I'm playing my PS3 on a 46" 1080p TV and my PS3 games look great in 720p.
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Ps3 problem
Change the resolution on the ps3 to accept 480p, 720p, 1080i, 1080p.
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 problems
if the game doesn't support 1080i , then you could only get 480p.
did you try cod4 ?
May 21, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Call of duty 4 1080p
First off, Sony doesn't make Aquos they make Brava. Sharp makes Aquos. Secondly, I am unable to uncheck 720p how do I do  this?
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Pink HDTV screen PS3
check that you have all avalubal resulutions sulected in your displt settings i.e. 480p 720p 1080i and 1080p all the ones your tv will support my ps3 was doing the same thing untell i checked 480p as well as 720p and 1080i now when I play a dvd my tv swiches to 480p and the dvd will play.
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
Call of Duty 4 Modern Warfare
It is 1080p, but your tv must be compatible with 1080p your tv more than likely only supports 720p. My tv only supports up to 1080i and that is what I play in
Dec 06, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
80 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
