Question about Kyocera FS-C5015N Laser Printer
Stopped printing in color - Kyocera FS-C5015N Laser Printer
  • Muzu (Randi) Kashi
    Muzu (Randi) Kashi May 11, 2010
    Sounds like you need to send the Printer in for replacement or repair. You will probably need proof of purchase. If it has been purchased within the last year. They will replace or fix it free of charge. I can help with this process.
    Muzu
    Genius:
  • 1,011 Answers
Since you give very little information, my immediate suggestion is to check the print properties in both the driver and the application you are using to make sure that you haven't set the printer to print in "Grayscale Only."
Don
Posted on Nov 12, 2009
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Oct 28, 2015 | Konica Minolta BizHub C252
Tip
The green light is blinking constantly and the printer won't print
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
on Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
HP Laserjet 4700dn suddenly stops printing in color although the cartriges are new and were working well. What is the problem?
>Go to menu settings, select set as default setting, do color calibration.. try for the print..> take configuration page, verify the firmware version, if low, download from hp web site, up load as specified..
Feb 01, 2012 | HP LaserJet 4700DN Printer
Light is blinking but will not print
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Nov 09, 2009 | HP Deskjet D1341 InkJet Printer
Not printing, on light flashing
Nov 08, 2009 | HP DeskJet 3650 InkJet Printer
Cannon pixma 1500 printer stopped printing color ink is full
Print a test pattern print first to make sure that the problems is the printer and not the file you are trying to print , then check you color cartridge if it's empty.
Aug 17, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printer will not print in color
try to check  the printer setting of your printer maybe it enabled the black color printing setup in your printer. Then try also to remove the color ink cartridge then installed it back and try to print it again.
Jun 19, 2009 | Canon i860 InkJet Photo Printer
My HP printer stopped printing in color
sure...it is most likely a print settings issue on your word application, maybe. Check that print settings to ensure it's looking for color and not greyscale
Dec 12, 2008 | HP Office Equipment & Supplies
No color
it could be that it is set for mono printing in properties or did you est. if the color cartridge is empty?
Apr 25, 2008 | Lexmark X1240 All-In-One InkJet Printer
Kyocera FS-C5015N Laser Printer Logo
93 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
