Question about American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga
I have a AS dual flush flowise toilet and it seems that on the small flush it does not empty the bowl. As well the bowel does not hold at lot of water so when you are doing your big business, the remnents line the inside of the bowel.
    Top Expert:
  • American Sta... Master
  • 76,846 Answers
If u pull the lid off the tank you will see that the water level and the amount of water delivered for flushing is adjustable, most have a little float that u can move to deliver more water before the tank valve shuts off, move the foam float down to give more flush water, also u should be able to set the tank level higher, have done this on both my low flow's and got good results.
Posted on Nov 12, 2009
When we flush the toilet there is never enought water left in the bowel after...do i get more water
Make sure the small toilet fill tube in the tank is still running into the tank overflow tube.
Jan 12, 2014 | Pfister VTP-E70W Kamato One-Piece Dual...
Water splashes out of toilet fbowel when flushed
Try lowering the float level. This will reduce the amount of water in the cistern and lower the pressure on the flapper so when you flush the water will not flow as fast into the bowl.
May 27, 2012 | Home
We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
VitrA dual flush toilet doesn't flush enough water
maybe by shortening the chain length on the flapper valve might help
Jul 24, 2010 | VitrA Aria Toilet with Elongated Bowl/...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
Not enough water in the toilet bowl
Adjust the floating stopper in the tank to allow more water to fill the tank
Oct 29, 2008 | American Standard Flowise 2480.216.020...
American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga Logo
100 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
