Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
USB error just recently when i turn on this hard drive it says high speed device connected to a non hi speed usb port,it says it every time now,but never did before,my transfer is slow like a usb 1,But all my ports are usb 2,its a newer computer.Any recommendations???I have tried different ports,and checked my operating system for updates,i am using windows xp
  • moeouellette Jan 08, 2008
    the bios on my computer is fine all other high speed devices work in these ports.Did you mean the bios settings in the external hard drive??
  • Fabrika Latina - NJ Latin Wedding DJ
    I have the same problem, and I know it's the hard drive (Acomdata 250GB), because I also have the Maxtor 500GB model 3200, and both computer recognized the Maxtor HD, the one at home and the one at work, but it won't reconigzed the usb 2.0 connection on the Acomdata HD...
    It's not the cable because I switch the cable too.
    Please help me, because I need it for my backup music HD.
    What it could be?
    Thanks in advance for your help...
    Rudy www.djruco.com
  • 3 Answers
Dear one
your problem is caused due to wrong bios settings of usb.
in bias setup,
find usb settings and choose option "disable usb 2.0 support"
Posted on Jan 08, 2008
I have a seagate external drive of a capacity of 250GB. the free space available is 177 GB. the hard disk is very slow? please help?
Are you connecting this high-speed ("USB 2.0") device to a low-speed ("USB 1.1") USB-port on your computer? If so, and your computer has a "USB 2.0" port, connect your device to that port.
If not, then purchase an add-in PCI card for your computer, to add "USB 2.0" port(s).
Nov 10, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 22, 2010 | Philips Computers & Internet
I have a toshiba external drive 250GB. model HDDR250E03X. I believe the socket for the usb cable is loose...sometimes its working, most of the times now--its not! I already bought a new usb cable but still...
I have experience this error recently.
Normally these drive with high capacity like yours need to be installed with usb 2.0 cable and connected to a usb port that support usb2.0
Check if your motherboard support this.
Also if you are using an extension cable or a usb port hub try to bypass this and connect directly to the mainboard at the back
One thing more
At times new Hard disk need to be formatted, so go throught disk managemnent and locate your disk to create partition and format the Hard disk.
If you need more help
please revert back
I will be glad to help you for further problem.
One thing you can do is to check your Usb port with another device eg: a usb pen or usb printer.
ok
cheers
Uttam
Jan 26, 2010 | Computers & Internet
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Usb 2.0
If you connect a device like this that is running in USB 2.0 to a computer or device that only supportrs USB 1.0 the speeds there will be just the USB 1.0 , because it will depend to the USB port that its connected to.. that's why its advisable that if you have a device that runs in USB 2.0 better connect it to a device also that supports 2.0 so you can get the 2.0 speed..
Hope that helps.......
Sep 06, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
Zippy USB external hard disk case (2.5
I know this is an old thread, however if it helps any one try this:
Zippys power supply failed for me also. The problem here is your case support USB 2.0 ("A high speed USB device") and your port is only USB 1.1 ("plugged into a non-HI-SPEED usb hub"). This will not give adequate power to the drive. So use a y-cable (http://www.toshibadirect.com/images/ui3/accessories/toshiba-usb-y-cable-ba82010-300.gif) and connect one end to your casing and the two pins at the other end should be connected to two USB ports. (get it at http://www.toshibadirect.com/td/b2c/adet.to?poid=438342).
Another costlier way is to upgrade to USB 2.0 by a card like this http://www.belkin.com/support/download/download.asp?category=1&lang=1&mode=
or even better a USB 3.0 card : http://www.asus.com/product.aspx?P_ID=lGYmelQ8mJvPtYTv
Jan 28, 2008 | Computers & Internet
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
69 people viewed this question
Top Acomdata Computers & Internet Experts
Donna Sander
mark
mark
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
