Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
The oven door won't shut completely - there is a gap at the top.
  • 6 more comments
  • rhoth Jul 07, 2008
    I have the same problem. When the oven is turned on, there is a gap on the top and on the sides. The gap is wiide enough where the oven light won't go out at times. Any solution to this?
  • byrd234 Oct 04, 2008
    I am having the same problem.  The door will not shut tight and the light comes on.  I had service come out once.  NO luck!  Any solutions?? Ideas? Thoughts??
  • Anonymous Jan 08, 2009
    same problem exactly, oven door will not close completely and there is a gap at the top and the oven light stays on alot. We tried to work on the hinges, but can't figure anything out. Had a service tech come out and the problem is still there.
  • Anonymous Feb 14, 2009
    My Jenn-Air 30" electric double wall oven JJW9830EEB does not heat properly either. Unit has had hinges replaced twice with no improvement. Service tech wanted to replace entire door but warranty company claims they can't find parts anywhere for this in-production model (or are just trying to dodge the problem). Bottom unit heats better than top, but still takes way too long to heat. 1) any suggestion on where to get replacement parts and competent service? 2) overall, this model totally sucks.
  • wjherman Mar 21, 2009
  • Anonymous Mar 24, 2014
    wall oven wont latch
  • Ping Wu
    Ping Wu Dec 18, 2017
Lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Posted on Jan 08, 2010
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Jenn-Air Expert
  • 91 Answers
    New Friend:
Same issue here, wall oven microwave combo. The first time the oven door is not supported until fully opened it will tweak the hinge assembly so the door does not close. It only takes one time. Jenn air sent me three sets of hinges too. Sister in law opened the door part way and let go after first fix and it was tweaked again. Jenn air products are bad. Save yourself money and headache and don\'t buy from them.
this should have been a class action suit.
Posted on Mar 29, 2014
I'm on my 3rd Jenn-air down draft range and all had a similar problem, always right before or right after the warranty expired. This time it's the control panel, which is on back order from the factory until after January 1st. There'll be no holiday cooking at my house this year. I'll never buy Jenn-Air again!
Posted on Nov 12, 2009
I had this problem and it was fixed under waranty. The was a recall on the hinges and a repair kit was provided under waranty. My ove model is jjw9630cab
Posted on Oct 04, 2008
Can the top and bottom doors be switched? (jenn-Air double oven jjw9430dds)
I have this same problem, top door won't close completely and the light stays on. Help donmash@aol.com
Nov 24, 2010 | Jenn-Air JJW9430DDS Stainless Steel...
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
WW30430
lower oven gives Fr code when turned on
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air single electric wall oven #JJW9530DDS
try to open the door see if the door latch is extended if it is locate the light switch on the oven cavity and hold it in then hit start then cancel or stop the latch rod should go back
Dec 27, 2007 | Jenn-Air JJW9530C Expressions Collection...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
735 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
