Question about Samsung RS2630SH Side by Side Refrigerator
Frige door won't close all the way. No pressure on door
  • Samsung Master
  • 3,361 Answers
Make sure there is nothing on the shelves protruding in the vicinity of the bars on the door.
I have seen this to be the problem on a number of service calls.
It could possibly be in the lower door hinge too. A bad or loose cam can cause the door not to close.
Posted on Nov 12, 2009
3 Suggested Answers
  • 1891 Answers
SOURCE: maytag ref top freezer door
ck the cams on the door hinges also the door seals may not be strong enough and need replacement . mm
Posted on Aug 11, 2010
  • 842 Answers
SOURCE: doors won't close independantly. Magnetic
Has the unit recently been moved or the doors removed at any time? Either the door are not aligned or they are damaged around the hinges some how. I would adjust doors from the top of the unit, assure not product (food) could obstruct the door from closing. Lastly double check closer at the bottom, this is a two piece system and I had seen this come apart recently.
I hope this helps
Posted on Aug 11, 2011
Why does my frige motor turn on when I close the door and off when I open door?
It's designed that way for energy saving purposes. The motor shuts down when the door is open so that it's not producing more cold air to just fly out the door. Then when the door shuts, the cooling mechanism kicks back on again for business as usual.
Oct 20, 2014 | LG Refrigerators
I CANT OPEN THE FRENCH DOOR
My guess it that they are frozen shut which means the little door heaters are not working or you have a bad door gasket. If you have a hair dryer I would blow it around the seams of the doors until they give. Or you can unplug the frige and let it thaw for a bit then try. Or the break between the frige air and the freezer may be frozen closed then the pressure difference can hold the doors shut, in that case you need to unplug it for a bit and try opening the doors periodically
Sep 06, 2012 | LG LFC20760 Bottom Freezer French Door...
Doors won't close independantly. Magnetic "strips " hit and freezer or frige stays open slightly
I hope this helps
Aug 11, 2011 | GE GSS25LGM Side by Side Refrigerator
GE "frige model GTS18XCSFRBB; has
Loosen the screws on the top bracket on top of the refrigerator.
Not the hinge between the doors.
Pull up on the door handle and tighten the top bracket screws.
Mar 19, 2011 | Refrigerators
Maytag ref top freezer door pops open when frige door is closed and freezer door does not close all the way
Aug 10, 2010 | Refrigerators
Amana, top single door drags when closing
I will tell you how I fixed this problem for a one time payment of $19.95. Or, go to appliancerepair.com and get the answer for free. There! That'l FIXYA.
Dec 21, 2009 | Amana Freezers
Both doors open at same time
check the leveling of the frige. if unlevel it will offset the doors. with the doors closed they should be as close to even across the top
Oct 29, 2009 | Refrigerators
Problem W/ freezer door
Since you checked the top for level and it was ok you should check the sides for plumb with the level. The fridge has been racked so it is now a parallelogram and not a rectangle. You will have to rack it back to get the door to fit. Basically you will have to push the top of the fridge on the high side until the body is bent back. You will have to eye-ball it.
Apr 30, 2009 | Refrigerators
Refrigerator door doesn't close and seal. Nothing is blocking it.
make sure big compartment door on frige side is completely closing and not holding door open
Apr 11, 2009 | Jenn-Air JCD2389G Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
316 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
