Question about Protron PLTV-37 37 in. LCD Television
Can not turn TV on or off with remote or with button on TV. and YES, it's plugged into the wall.
  • 11,361 Answers
First place to look will be the power supply module, look for blown fuse, burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 12, 2009
I need a manual for a Sharp 19NV88BK television. The volume is stuck in the stereo mode, cannot lower it manually or with the remote. TV responds to remote except the volume.
Remove wall plug to the television.
Sit down, drink half cup of tea.
Put new batteries in the remote.
Drink other half cup of tea.
Put wall plug back in as all the power internally should be dissipated.
Try remote again.
Remote still not working? Clean buttons with wet cloth and dish liquid, turn remote upside down, wait 5 minutes. Clean buttons with damp clean cloth.
New Remote
http://www.sharpremotes.com/index.cfm?page=4
Manuals are here
Sharp Corporation Sharp Global
Nov 29, 2016 | Sharp Televison & Video
Vizio remote won't control tv
I just had the same problem. I call Vizio and this is what they had me do that did fix the problem.
1. Unplug the TV
2. Hold down the power button on the TV for 30 seconds (yes, with it unplugged and do not plug it back in yet.)
3. Take the batteries out of the remote.
4. Press each button remote twice to ensure that they bounce back and are not stuck.
5. Place new batteries into the remote.
6. Plug the TV back in. Not into a power strip if possible. ( I did not have an available outlet so I used a power strip.)
7. Try turning the TV on using the remote. (My TV turned on. All of the functions worked - problem fixed.)
Hope that this helps.
Nov 17, 2013 | Vizio New Original M3D550KD Remote Control
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
When we turn the tv off with the remote, we have to unplug the tv from the wall to reset the tv so that it will turn back on. Once we turn off the tv, it will not power back up with the remote or with the...
The power supply board is the cause.That the board,where the power a/c cord plug into it.Tries website like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Panasonic TCL32X2 32 in. HD-Ready LCD TV
Vizio pop of death, no pic no sound just black screen,
You may need to use the actual plug this time. Unplug the unit from the wall and wait at least 90 seconds to replug it in.
Jul 27, 2010 | Vizio L32 32 in. LCD HDTV
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
When turning on the t.v. makes a clicking sound (Normal sound) but the t.v. doesn't turn on, no picture?I am wondering if the t.v. has a reset button or something?
Does any indicator light in front of the TV when you turn it on?
if the answer is yes, try turning on the TV by using the remote control. press any of the programme numbers 1-9 while pointing the remote at the TV. It is advisable that you install new batteries in the remote before attempting this.
If the answer is no then you should do the following:
- check the wall socket. try plugging another device into this socket to see if there is power present
if all the above fail thentake the TV to the repairman.
Oct 02, 2009 | Televison & Video
My little colby dvd player wont open or close and it wont turn off. if it would open, i would try to reset the remote..yes, i have plugged and unplugged and have it plugged directly into tv???
I assume you've tried plugging into a wall socket instead of TV?
Probably won't work, but push and hold power button on unit 10 seconds then release, for that matter try all buttons. Not uncommon problem, usually you have to UNPLUG unit, disassemble to remove DVD and discard unit if cheap enough.
Sep 26, 2009 | Televison & Video
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
Sony kf50xbr800
juzz i suggest that u would unplug the unit for a couple of minute the plug it back in on a wall outlet.use the tv/video button to change the video input if that button didnt work it may require service....jake
Dec 07, 2006 | Sony Grand WEGA KF50XBR800 50" Rear...
Protron PLTV-37 37 in. LCD Television Logo
44 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
