Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A
Stopped running, don't know where to start - Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A
    Scholar:
  • 79 Answers
First check to make sure you have 120 volts to the unit. If you have power to the unit you then need to check the temperature control to see if it works(closes) and gives 120 volts to the compressor. Does the compressor make any noise like it is running and does the compressor get warm or very hot. Try this first.
Posted on Nov 12, 2009
Why did my Igloo FRF690 stop freezing?
Great ? but need more info
1 is compressor running or fans running can be compressor has stopped running and need new start relay
Feb 24, 2017 | Freezers
Compressor runs but fans dont.
If the compressor is running and pumping with no heat produced, you have lost refrigerant.. Most modern freezers have a controlled fan so the coil can freeze before the fan starts.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
I have to push on my freezer door to keep the blower running
there is a loose connection at the rear of the freezer near or around the compressor unit , i strongly advise you to get a professional to look it.
Regards
Dec 16, 2012 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Chest freezer power light on, run light off and all my food is defrosted. How do I fix it
Take off the service panel and check for the compressor running. Can you place your hand on
it or is it too hot. If it is you might change the relay to the compressor.Take your model no. to your local parts store and they will help you look at the part and exactly where it is located (on the compressor) Easy change out.
If the compressor is not running at all then remove the two wires to the thermostat and plug them
together (They will plug together if you turn one backwards and plug it into the other.)
Make sure you have unplugged the freezer while you are doing this.
Now you have routed around the thermostat.
If it runs then replace the thermostat and youre done!
If not after the relay and thermostat check it wont run then you have a bad compressor.
On the relay ask for a hard start relay for a freezer or ref. at the parts store. They know exactly
what it is. Its even easier to install. Don't be shy to repair this. You can do it or condemn it
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Magic Chef Freezers
Freezer tempreture drop to -38F even when is set to #3
does the compressor ever stop running? If not, the trouble is in the controls. If it does, the temperature sensor is probably bad. Start there and let me know if I can be of further help.
Jan 20, 2011 | Turbo Air 49 cu. ft. / 1388 liter...
Can I plug my freezer into a surge protector
i know where your going and its a good thought
read your compressor, it will label the start up amp,
it may even be on the model label
it will give you the rated amps and the start up amps
this is current draw to run
as well as start up a stopped motor
depending on the age
most units use about
short of that use a 3x method
if it has the run amp x3 is startup
then read your surge protector if its rated higher than the amps needed to start the unit
then you should be fine
i will say most SP are rated at 15amps
my freezer is rated at 18amperes
Oct 17, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Unit shutting down and temp riseing to 100 degree
If the start relay and cap are ok then I'd say it's time for a new compressor. Have you tried running the compressor directly with a direct start circuit? cheers
May 13, 2009 | Coldtech 40 cu. ft. / 1133 liter...
FREEZER FAN HOWELS AND STARTS AND STOP STARTS AND
Your freezer fan will need to be replaced to keep it from stopping. Try to find the complete model number so I can help you fix and or replace the fan. Let me know, Thanks, Sea Breeze
Mar 21, 2009 | GE Freezers
Freezer stopped working
A no power to the compressor is a good sign as far as being repairable is concerned. Locate the temperature control. Unplug the freezer and jumper the two main wires that connect to the control. Plug it in and if the unit runs replace the thermostat.
Jul 04, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Stopped running
try putting on fast freeze. if it starts up this means thermostat is faulty. get back to me if you want
Apr 04, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A Logo
105 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
