Question about Mitsubishi WS-65869 65" Rear Projection Television
Still not working after replacing the capacitors
I have replaced the capacitors in the tv and it is still not working. It will click on for 3-4 seconds with the green light on. The green light goes off after those 3-4 seconds. There is only 1 minute of blinking after unplugging or pressing the reset button.(normal). The given error code is ' one blink two blink' which is no error. I have seen other posts indicated that it might have a bad IC, piso fuses, horizontal convergence problem. I don't know. I don't know where these items are located in the tv. So any help regarding what could be wrong or where I can look at some of these part would be great. Should note there is a white ceramic looking 'thing' near the back that is the source of the clicking. Does not appear burnt or broken.
Thanks,
Jim
  • Anonymous Nov 21, 2008
    i have the exact same problem
  • Anonymous Jan 28, 2009
    Bad capacitors
    Novelist:
    Champion:
  • 211 Answers
Hi Jim, The problems I have found on these similiar sets are power supply problems and Horizontal transformer ( Flyback transformer ). The clicking I assume you are hearing may be the flyback transformer ( thats the big black transformer with the big red wire along with a couple of other wire coming off it ). The horizontal transistor is sometime the cause of this also, so if you have a transistor, or diode checker, check the horizontal transistor first. If the transistor is bad, it may be an indicatioon the transformer is also bad ( one will burn the other out sometimes). I hope this helps in some matter. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
WELL IT MAY SEEM LIKE THE END BUT ITS NOT. YOUR TV HAS BAD CAPACITORS ON THE POWER SUPPLY.. THESE CAPACITORS ARE PREVENTING THE RELAY TO STAY OPEN AND GIVE POWER TO THE REST OF YOUR TELEVISION.. THAT CLICKING SOUND YOU HEAR IS THE RELAY OPENING AND SHUTTING DOWN.. THOSE CAPACITORS NEED TO BE REPLACED.. IF YOU OPEN YOUR TV AND FOLLOW THE ELECTRICAL CORD.. IT FIRST CONNECTS TO YOUR POWER SUPPLY... LOOK FOR BAD CAPACITORS THAT ARE BULGY ON TOP.. OR BLOWN.. REPLACE WITH SAME VALUE... THE VOLTAGE COULD BE A LITTLE HIRE.. BUT TRY TO KEEP THE SAME.. BEFORE YOU TOUCH ANY OF THEM.. MAKE SURE YOUR TV HAS BEEN DISCONNECTED FOR 3 DAYS.. THOSE CAPACITORS HOLD ALOT OF POWER EVEN AFTER DISCONECTED... MORE ADVICE AT WWW.BESTDIRECTORYSOLUTIONS.COM FOR FREE.
Mar 16, 2012 | Philips 50PFP5332D 50 in. Plasma...
Power clicks on then shuts off
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Feb 22, 2012 | LG 50PT350 50 in. Plasma TV
Tv shut off while watching. pulled back off, led is lit on board, turn tv on hear a click and light goes back out
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Oct 06, 2011 | Sanyo DP50747 50 in. Plasma TV
HPT4254X/XAA clicking noises? Cuts itself off and continues to make clicking noises as if it is trying to turn itself on. I've had cheap tv's for 20 years and no problem. I'm not...
The tv power supply board it is the 90-95% the problems and the causes.That the board where the tv power a/c cord plug into it.Those capacitors components parts the tvs corporation put on tvs are under voltages for low heat resistance most of the times and dies very quickly, to dies as times used a lot of tv on like 3 or 4 hours a day within a year or litte bit more.U have all the tools and understanding basic electronic also can do basic soldering work too?Yes?Take the the tv aparts and check the tv power supply board carefully for dying and leakages capacitors components parts.These dying and leaking capacitors parts are alway bulges up or puffing up on to it tops.All these dying and leaking capacitors parts that are bulges up or puffing up on to it tops.All these dying and leakages capacitors components parts must have be replaced like the same Micro Fared and those voltages on the new capacitor parts u are replacing should be in higher voltgaes like 5 or 10 voltages higher than those old capacitors parts u are replacing.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 25, 2011 | Samsung HP-R4262 42 in. Plasma Television
I have a Samsung LN52A650A LCD TV that 3 years old. Today when I go to turn it on it just clicks and does not turn on. The clicking wont stop...it clicks about once per second. I have to unplug the TV to...
The tv power supply board have dead components parts call capacitors most likely.U have all the tools and understanding basic electronic also can do basic soldering too?The tv power supply board that the board where the power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and dead capacitors parts.These capacitors parts are alway bulges up or puffing up on to it tops.Must replaced all these dying capacitors parts are bulging up ur puffing up on to it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
May 11, 2011 | Samsung LN52A650A LCD TV
42 philips plasma tv
my tv wont turn on makes clicking noise and there is a green light in the back flickering
Jul 11, 2010 | Philips Magnavox 42MF521D/37 Television
When i turn the power on the tv clicks for up to ten min before the picture comes on. is this fixable?
Yes,very fixables.Ur tv power suppply board have these parts call capacitors.They are dead and gases leakages,not total,but dying.These capacitors they alway bulges up on it top,puff up on it top,these capacitors are dying,that why tv still have power but it take up to ten min. clicking to recieve power to the rest of the tv.The power supply board,that the board where the power a/c cord plug into it.U have basic understanding of electronic's?U have tools,soldering iron,desoldering pump,solders?Take the tv aparts.U just looking,searches all around the power supply board and replaced these dead,dying capacitors that are bulges,puff up on it tops.Replaced these gases leakages capacitors,ur tv will have it power back to normal and work on the first click.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A450 40 in. LCD TV
My TV can't turn on and getting clicking sounds...help please!!!
I have a Samsung Plasma PN50A450 and one night the TV turned off and the result of trying to turn it back on was simply the set trying to turn on, making a click sound and nothing happened. I pulled the back off, and attempted the capacitor fix that is well documented on the Samsung LCD TVs. I did have a swelled capacitor that I replaced and also replaced the other capacitors that were the same Microfarad rating, temp and voltage which were replaced in a popular UTube video. That did not solve my problem, so I went onto Ebay and bought an entirely new power board for 69.00 plus 14.99 shipping. Replacing the board took about 3 minutes. TV is now working fine and will go back up on the wall in a day or 2. Note, the power board in my TV was a BN44-00205A. That board is no longer in stock anywhere ( I believe because it has been determined to be a bad board) I replaced it with BN44-00207A. Which I suspect is the board that is being used for replacements of the bad BN44-00205A. It fixed My TV. Hope this helps you. BTW, Both power boards are listed for replacing a board in the PN50A450, but the BN44-00207A Specifically states its for a PN50A450P1D. I took a gamble that the BN4400207A would work. It did.
Mar 01, 2010 | Samsung PN50A450 50 in. Plasma HDTV
I go to turn it on and the vizio label turns white then clicks off
The Vizio VP322 is notorious for having bad capacitors on the power supply circuit board. They will probably be bulging and may have electrolyte leaking. I replaced four bad capacitors (with a different brand just in case) and fixed it. Total cost under $10. A lot cheaper and better than replacing the whole circuit board which may contain the same "faulty" capacitors from the factory.
Nov 12, 2009 | Vizio VP322 32 in. Plasma TV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
475 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
