Question about HTC Touch HD Smartphone
Keypad problem I seem to have a problem with the keypad...I don't know why but I can't get it back on Full Qwerty...it is stuck on Phone Keypad in the Options tab. I have tried turning it off and on again but it still wouldn't save the Full Qwerty or Compact or any of them. What can I do??
  • vanilia4ever Nov 12, 2009
    well...I bought it recently...and not from the Uk..so I would have to go back to my country to fix it...which is kind of impossible...do you think it's broken?
  • Muzu (Randi) Kashi
    Muzu (Randi) Kashi May 11, 2010
    You can call the company and have them replace the phone if its still UNDER WARRANTY. If you need help I can help you.
    MUZU.
Seems like its a simple software malfunction. You don't need to go back to the UK to get the phone service or repaired. You just need to contact HTC regarding the issue and verify that you have a RECEIPT of purchase of this phone within the last (12) months somewhere here in the states and they will service it. This is actually very easy to do ;)
MUZU
Posted on Nov 12, 2009
Testimonial: "thank you so much"
How to Qwerty keypad download samsung corby2 3850
Dear Sir
i have Samsung corby 2, i don't like the normal keypad i need to change it to landscape keypad for all mobile functions like messages,....
thank you for your help
Jul 05, 2012 | Samsung Corby 2 GT S3850
My n8 keypad has turned into a horizontal qwerty keyboard. how do i get it back to other vertical type
On vertical you only get Alpha numeric keyboard , full QWERTY is only on horizontal . Wait for Symbian Ana it will have QWERTY in Horizontal mode too.
If you like the answer do give me all thumbs us Farhan www.senseapplied.com
May 27, 2011 | Nokia N8 Cell Phone
HTC Wildfire. How to come off qwerty keypad to standard mobile key pad
From the main homepage press menu and select settings. Now select Lanuage and keyboard, select touch input and finally 'keyboard types' this will let you change the type to QWERTY, phone keypad or compact QWERTY.
Aug 25, 2010 | HTC Wildfire Cell Phone
QWERTY keyboard is not working, I have a Samsung
check keyboard matt... check keypad membrane... check keypad interface... or may it be the keypad IC that requires a cellphone technician to check -up/repair...
May 26, 2010 | Cell Phones
How to take apart the samsung gravity sgh-t459
Remove battery cover and battery. Using a #00 philips head screwdriver, remove the 6 screws around the perimeter. Slide phone open and carefully pry up on the edge of the green (or blue) trim near the space bar. The colored back should unsnap. There will be two philips head screws visible on the now exposed circuit board. Remove these and carefully pull up on the rectangular ribbon cable to disconnect the main circuit board from the keypad circuit. Carefully peel the two button contacts from either side of the phone. On the spacebar edge, there will be a clip holding the circuit board in place. Gently pry it away from the board and the board should come free (there will be clips on the other side but you should be able to lift the free side of the board up and slide it out from under the clips). Remove the QWERTY keypad. Unglue the remaining ribbon cable from the keypad frame. Undo the 8 silver screws securing the keypad frame to the hinge and lift frame off. There will be 4 screws visible on the back of the LCD case. Remove these and insert a thin plastic spudger at the top of the frame and carefully work your way around. The two halves will separate (should hear two snaps on each side). You will now be into the keypad/LCD section of the phone. Removing everything else is pretty straight forward. Follow these directions backwards to reassemble.
Oct 10, 2009 | Samsung Gravity SGH-T459 Cell Phone
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
I cannot get the Qwerty Keyboard on my HTC Touch HD
Hi I just got this phone yesterday - its really awesome. I had the same problem - to change the keyboard just press the keyboard button on the bottom like you usually do to bring it up, then press the little up arrow next to that button. This gives you a selection of keyboards to use, they are much better as they are TouchFlo 3d keyboards.
Mar 25, 2009 | HTC Touch HD Smartphone
No qwerty keyboard
hi! i just had my "missing qwerty keyboard" problem solved today!  im from hong kong and just got my viewty the other day, when i realised that i didnt have the qwerty, and there were no answers anywhere (manual, online...) i brought my phone back to the store.  apparently, eventhough the phones' language has been set to english, you'll still have to set the "writing language" back to english.  you can do this by going to: create new message >> message >> clicking on "options" (button at the bottom left of the screen) >> writing language >> then choose "English" >> OK >> and viola!!  you'll see a confirmation that "language has been changed"
you can double-check by clicking on that drop-down menu button with the "pen icon & A" that allows you to choose text input preferences.  you should be able to find "keyboard" there.
enjoy!!
(btw, i love my viewty!!  best phone ever!  i hope youre enjoyin your phone as much as i am!)
Bebe
Feb 11, 2009 | LG KU990 Viewty
HTC Touch HD Smartphone Logo
112 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
