Question about Microwave Ovens
Viking Micro noise
PROBLEM: only during the microwave function, the unit makes loud "buzzing" noise 1 to 2 seconds after start up. All other functions work fine...other than buzzing. No sparks or other abnormalities.
The unit heats items in a normal time range, ie, nearly boils a cup of water in 1 minute.
There is NO abnormal noise while convection bake or broil is used.
As stated, other than the "buzzing or rattling" noise, the unit seemily works fine.
The unit is "new" (no warranty, bought as is) so there is no recourse with manufacturer.
Any insights welcome.
Thank you.
Dave
  • dave y Jan 08, 2008
    The abnormal "noise" is continuous for as long as the microwave is on. Again, all other functions are normal. The noise starts 1 second after start up and lasts the whole cycle. The noise is not intermittant and is only during the microwave function.
  • 579 Answers
The noise is probably from the high-voltage transformer. When it is overloaded, the excess magnetic field it produces vibrates its wire coils. Odd that it only happens for a brief time. It is either defective itself (in which case it may go a long time) or it is getting overloaded by the magnatron/capacitor/diode on its output (in which case it will get worse shortly)
Hope Ya Fix it
Posted on Jan 08, 2008
  • Greg Collins Jan 08, 2008
    Ah, buzzes the whole cycle - that is the typical case. The high voltage cap and diode need replacing.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Dec 10, 2012 | Samsung SMH1622W
WHAT IS PURPOSE OF NOISE FILTER ON VIKING VMOC205
The noise filter is to block electrical noise, not auditory noise. "Noise" in electronics means any unwanted or unintended electrical signal.
The purpose of the noise filter is to help prevent any electrical noise generated in the wiring of the microwave from getting into your house wiring, which could cause interference with or disruption of other devices.
If your microwave is making auditory noise, then it may be a loose cover or panel, a rubber bumper fell off the high voltage transformer, or one of the components is failing.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the magnetron can be bad without that sound.
If either of those two were bad, it would not cook.
Oct 30, 2012 | Viking Microwave Ovens
Microwave not heating
It most likely is either a issue with the inverter (power supply) or the Magnatron (main unit) in this oven.
It could be a thermal fuse inside but the noise sounds more like Inverter or Magnatron.
If not a cheap unit have a shop take a look and get an estimate.
Jun 15, 2012 | Amana Microwave Ovens
My r880f microwave has lost its microwave function only grill etc still works any ideas ?
It could be that the magentron has failed. Does it make a loud hum or buzzing noise when you try to use the microwave only function? If it does, chances are that the magnetron has shorted out. The replacement cost can be as high as the cost of a new oven, so it rarely makes sense to fix.
May 24, 2011 | Sharp Microwave Ovens
Frigidaire PLMV168K2 micro wave stopped heating food. Still has turntable and light functions. Seems to have more of a power load after initial start. The buzz is more intense than normal.
A loud buzz is a symptom of a shorted magnetron or high voltage diode. Would recommend that you take it to a qualified repair facility if you want it repaired, but if the magnetron has failed, the part costs can equal that of a new oven.
Dec 06, 2010 | Frigidaire PLMV168 Microwave Oven
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
Microwave Ovens Logo
357 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
