Question about Carrier Heating & Cooling
Will conditioner run same amps cold weather - Carrier Heating & Cooling
    Master:
  • 969 Answers
Usually connected to a 30 amp & 40 amp double breaker, if it is a heat pump. 30 for cool, 40 for heat, to turn on 1 or 2 heat strips. heat strips are rated 2 5kw each.
Posted on Nov 12, 2009
What makes the condenser fan shut off but the compressor keeps running but not every time
Condenser fans cycle on and off to control the temperature/pressure of the refrigerant in the condenser. This is normal operation.
As to cooler weather start up and tripping the breaker; how cold is it when you are running it? If it is too cold you could be pumping liquid refrigerant back to the compressor, slugging it and causing it to trip a breaker. However, many things can cause an air conditioner to over-amp and trip a breaker but this tends to be more problematic as the weather is hotter.
Feb 20, 2015 | Heating & Cooling
How long after the air compressor kicks off will it kick back on
it depends the temperature,never is the same time,depends how hot or cold is the weather.depends the thermostat regulation by the user.
colder sets get more time running at hot weather
Jul 15, 2014 | Goldstar Heating & Cooling
My coil froze up last winter. What would cause this to happen?
Air conditioners that run in cold weather need special equipment installed to allow them to run in cold weather. It can be done by experienced techs.
You need to find the right guy that knows how to do it and then spend the extra $$$ to get the A/C to work right...
heatman101
Oct 13, 2010 | Goodman Heating & Cooling
Very cold outside should we swithc to aux heat to be more effice
I recommend running the heat pump even in the cold weather. If you like you could turn to EM heat around 10 degrees, but you do not have to. The newer heat pumps seem to work better than the old ones did in the colder weather.
Jan 04, 2010 | Goodman CLJ30AR32 Air Conditioner
Will conditioners run same amps and cold weather
All depends on the heat load so the answer woud be no.
Nov 12, 2009 | Goodman GMS90703BXA Heater
Not blowing cold air
Your in house core could have frozen over. check the core inside the indoor blower unit. it may have frozen over. this will interrupt the cold air function.
May 28, 2009 | Weather King 10AJA6001AH Air Conditioner
Charging a central air conditioner in the cold weather
The copper tubing has cracked and water has leaked onto my roof. I have shut off the water valve that runs to the aircodtioner but cannot get someone over until the morning. It is a cold night. Will this be sufficient until I can get someone over in the morning. It's not that cold but there is a possible storm coming thru.
Oct 05, 2008 | Goodman CLQ36AR49 Air Conditioner
Weather king
sounds like very high humidity in the house.....is water running out the drain?
Aug 06, 2008 | Weather King 10AJA2501AH Air Conditioner
No cold air
Freezes up is only caused by either low on freon or low aiflow across the indoor coil, which could be caused by dirty or blocked filter ,,dirty fan blower wheel or pluged coil.
May 27, 2008 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
52 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
