Question about Whirlpool GHW9400 Front Load Washer
The tumbler will not turn. What could it be? - Whirlpool GHW9400 Front Load Washer
  • Whirlpool Master
  • 43,501 Answers
My best guess would be that your belt either broke or at least jumped off. If it is just off it may be a bad tensioner pulley. If the you can hear the motor run and it is not turning then something has to be wrong with the belt not driving the tumbler.
Posted on Nov 12, 2009
Key wont turn pass acc it locks how can i fix
Ignition key cylinder tumblers are worn out!
Time to replace the cylinder.
Help prevent this from happening again by lightening your key ring load. A heavy key ring puts constant pressure on the lock tumblers and wears them down to eventually deform and prevent the tumbler cylinder from turning.
Most people employ the philosophy, "if it jams, just force it", which bends the weakened lock tumblers and hastens destructive wear.
Dec 06, 2015 | Cars & Trucks
I forgot the combo for my Kryptonite bike lock US PAT 593412/6422051, can you please help? Thank you
Another way is to pull apart the ends till you have tension on the tumblers. As you place tension try to turn the tumblers. As you feel each loose or tight tumbler is how you can find your combination. I open this type of combination lock like this all the time. First look for the tightest tumbler, turn it until it feels looser and next look or feel for the next tight tumbler. All the tumblers do not block the release at once. You are looking for the first tumbler to adjust, the tightest one, then the next, continuing until you find you have released all the tumblers. This has worked for me with any brand of inline tumbler release system out there. Good luck, usually takes me about 10-15 minutes to find the code. This method can be used on regular locks with a changeable combination as well. It will just take a little time to get to know how much tension to use as you go through each tumbler. Similar as to how you pick a regular lock system. Good luck, definitely doable.
Jan 24, 2013 | Kryptonite Cycling
How replace a lock tumbler on a 1995 Mercedes benz c220
If the key does not turn at all in the ignition tumbler then your going to need to drill a hole in the side of the steering lock in order to manually release the steering lock and remove it complete with the ignition tumbler attached. If you get a new steering lock you can examine it to see exactly where to drill the hole and how to manually release it. If the key does turn at least to position 1 then all you need is the removal pins that slide into the small holes around the face of the tumbler. If there are no holes then once the key is in position 1 all you have to do is turn the tumbler housing to the left until is unscrews. Let me know if you need any further assistance on the removal if the key is stuck.
Sep 26, 2012 | 1995 Mercedes-Benz C-Class
Key will not turn
If your key will not turn at all there is a good chance that your ignition tumbler has gone bad. The tumbler is the part that your key actually goes into. The tumbler is fairly easy to remove, and the new tumbler will actually come with step by step instructions. A new lock tumbler will normally cost no more then $30. If that does not work the only other option is the ignition switch itself and those are more expensive costing on average around $150 or more. I hope this helps you out, and if you have any more questions please feel free to ask.
Aug 25, 2011 | Saturn SL2 Cars & Trucks
Is there an easy online guide to changing out the ignition tumbler in a 1992 dodge caravan?
First remove the plastic 2 piece shroud around steering column so as to gain access to the housing the tumbler sits in. Find three Phillips screws to remove in holes in the lower piece.
Turn the ignition key to the Run position. Insert a small tip screwdriver in the access hole on the bottom of the housing to push the spring-loaded tab which will free the tumbler so you can simply pull the tumbler out with the key.
Installation is the reverse. Be sure tumbler with key inserted is set to the Run position.
Depress spring-loaded tab, insert tumbler into housing hole with tab down. All the way in,
Turn key to the Lock or turn it off.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 10, 2010 | 1992 Dodge Caravan
Jeep - can't turn ignition key
your ignition barrell tumblers are getting stuck, you need to replace the barrell and tumblers at dealership. you can get the key to turn if you hold key in ignition and try and turn and at the same time tap the end of the key which normally jogs the tumblers to enable key to turn
Jun 01, 2010 | 2000 Jeep Grand Cherokee
03 chevy monte carlo can't turn key
Tumblers are going bad. Get a locksmith or dealer to replace.
Apr 15, 2010 | 2003 Chevrolet Monte Carlo
Key tumbler loose. Starts car but wont turn off
most likely its the ignition cylnder (tumbler)
Nov 13, 2009 | 1996 Ford Taurus
Oldsmobile 2001 intrigue Ignition main the key will not turn
Possible fix for the year of car is a worn key or tumbler or both. Check with Olds with your car vin number to cut a new key. If it's the tumbler, it will have to be re-pinned with new pins by locksmith or replaced with new tumbler. Rare occasions the turning of steering wheel frees the steering locks pressure hold on ignition tumbler. New tumbler can be reset to match door so as not to have two different keys.
Nov 12, 2009 | 2001 Oldsmobile Intrigue
Tumbler problems
try this, put the key in and turn slowlyat the same time turn the steering wheel left to right and do this several times. this may get the tumblers to drop like they should. please rate this
Sep 12, 2008 | 1999 Dodge Caravan
Whirlpool GHW9400 Front Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De
