Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Need info on how to change Chain - McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
    President:
  • 2,220 Answers
View the first 1:15 of this:
http://www.youtube.com/watch?v=cdqkIuVNUQc
Install the new chain like this:
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Yours is electric there are probably a few differences but the process is very similar.
Posted on Nov 12, 2009
  • 89 Answers
Remove the 1 or 2 nuts the right hand side of the saw remove the side cover
slide bar back and then off remove chain replace chain you will have tom adjust the chain tension screw to fit the bar back on the saw
At how many mi do i change cam chain
Les, The chain in the 2.3 is to last as long as the engine, normally if some thing was to happen, chain guides would wear first and you would likely here a rattling noise that would alert you to have things checked. This engine is known as an interference engine, meaning if chain did slip/break, it could cause real damage to engine valve train and pistons. If it would give you piece of mind and you have over 200,000 on it, have i changed. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Timing Chain Replace Mileage Ranger Forums The Ultimate Ford Ranger...
Repair Guides Engine Mechanical Components Timing Chain Cover AutoZone com
Motor Ford 2 3 Lts 16 Sincronizacin Timing chain kit installation
May 17, 2016 | 2008 Ford Ranger 2.3
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Does the 2012 kia soul, automatic have a timing belt or timing chain and does it have to be changed
they all have either a chain or a belt but normally do not need changed for several years . but if you what to know more about your vehicle buy a repair manual at any autoparts store
Feb 17, 2016 | 2012 Kia Soul Base Wagon 1.6L 4-cyl....
I don't know how to change the blade.
Chain saws don't have a blade,so i think that you need to give me more info about what your problem is.If you mean the chain bar that the chain runs along,then you need to remove the cover from the chain bar and then loosen the bolts that hold the bar on and then slide the bar back until you can remove the chain,once the chain is off you can then just pull out the bar.
Jul 29, 2010 | Garden
I'm receiving conflicting information about the 2004 Honda Civic Hybrid w/the 1.3 L engine. I need to know whether this particular model's engine has a timing belt or chain. No one, including a local Honda...
LOOK ON THE PASSENGER SIDE OF THE ENGINE AND SEE IF THERE IS A PLASTIC COVER AT THAT END OF THE ENGINE ..THIS IS THE ACCES POINT TO CHANGE THE TIMING BELT...
Jun 16, 2010 | 2004 Honda Civic
Working on a 2000 Audi A8. Need info on changing
If it's anything like the six cylinder engines from Audi, which I'm very familiar with, and from what I remember of the V8, you have a timing belt that drives the water pump, crank, and exhaust cams, and also includes a tensioner and an idler roller. The timing chains come into play in the cylinder heads. What Audi did was to only drive the exhaust cams off of the crank, using the timing belt, and inside each cylinder head there is a timing chain assembly that is used to drive the intake cams off the exhaust cams. On a periodic service (like the timing service) you only need to do the timing belt. The timing chains are only replaced if the tensioners fail - you'll know this by a diesel-like clatter from the cylinder heads. Failure of the chain drive assemblies is very rare, which is good because they're incredibly expensive (on the V6 engines they're upwards of $700 each). If you're doing this job because it's due based on mileage, don't touch the timing chains in the cylinder heads - only change the timing belt, tensioner roller, relay arm, hydraulic tensioner, idler pulley, water pump, and serpentine belt. You can leave the chains alone.
Dec 01, 2009 | 2000 Audi A8
Don't know if car has timing belt or chain
It has a timing belt.. it is recommended it be changed every 105,000 miles
Nov 17, 2008 | 2003 Dodge Stratus
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
149 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
