Question about Kodak EasyShare Z612 Digital Camera
I purchased a PNY 4GB SDHC memory card to use with my Kodak EasyShare Z612. The camera indicates formatting required. How do I format or are they compatible?
    President:
  • 1,653 Answers
You simply insert the memory into the camera, switch it on, go to the menu and then scroll through to Format and then accept. This will then take a few minutes and format the memory for use in the camera. Make sure that the batteries are fully charged before doing this.
Posted on Nov 12, 2009
  • 76 Answers
Does it have a place that says ok on your camera when it asked you to formatt if so hit ok , all its doin is cleaning off the card so its blank when you use it, and yes it should work in your camera
HOW do I format SD cards for Easyshare Z612? Can I use a "PNY 4GB SDHC card?"
You can Format by entering the camera's menu and find the format section. Click Here and see Pages 36-39 for detailed instructions on formatting your SD Card. Also your camera is not capable of reading the High Capacity SD cards (SDHC) so you will have to stick to the SD cards (2gb or smaller)
Jun 20, 2011 | Kodak EasyShare Z612 Digital Camera
Just bought a Kodak 4gb memory card, and camera says it needs to be formated, and I stick the card in and it says it can't be formatted
The Z612 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jun 02, 2011 | Kodak EasyShare Z612 Digital Camera
When i install team micro sdhc 4gb memory card in kodak easyshare z612 it says format .i select format but it keeps asking to format or cancell
First check make sure the SDHC card is unlocked I'll provide a diagram for that also I just checked your camera's memory capacity and it's only good for a 1 gig SD card which if using an SDHC memory card might go to 1.5 stretch to 2gig maybe but not a 4gig. My first impression is you got to much memory card for the camera. You might be able to go to the Kodak site and download updated firmware to allow the camera to function with the larger card but that's a maybe as well.
Here are the diagrams
And the memory capacity chart for your camera
Feb 02, 2011 | Kodak EasyShare Z612 Digital Camera
I bougth a 4GB SDHC for my kodak easyhare Z612 my problem is i coudnt format
The Z612 works with MMC and SD cards. It does not work with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible.
Dec 27, 2010 | Kodak EasyShare Z612 Digital Camera
How can you format a SD 4gb card for the Kodak EasyShare Z612 Digi Camera
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
May 13, 2010 | Kodak EasyShare Z612 Digital Camera
Memory Card
Hi...
The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
Good luck !!!
Regards
PCmania
Jul 06, 2009 | Kodak EasyShare C875 Digital Camera
Memory Card required formatting
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Dec 26, 2008 | Kodak EasyShare Z612 Digital Camera
    Kodak EasyShare Z612 Digital Camera Logo
    193 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
