Question about Husqvarna Chain Saw 20" Bar
My Husqvarna 16 in chainsaw is no longer working. The saw starts but the chain will not turn on the bar. Manually moving the chain results in the chain clicking and skipping over the sprocket. Could a groove in the sprocket cause this problem. The bar is fine on visual inspection and I tried a new chain without success. I also tried loosening and tightening the chain; this did not help
    President:
  • 2,220 Answers
Did the chain come off while at speed? The chain catcher causes burrs to form on the drive links when occurs. Without the catcher the spinning sharp chain contacts your leg. Were you wearing chaps? We don't need no stinking PPE!!!
Use a flat file on the drive link flats to remove the burrs.
My Husqvarna 16 in chainsaw is no longer working. - 34be72d.jpg 5ab118d.gif Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Posted on Nov 12, 2009
  • dontbother10
    dontbother10 Nov 12, 2009
    Remove the bar & chain. Affix a piece for tape to or mark one of the upper chain links. While wearing gloves, hold the bar parallel with the ground, the nose right, the tail left and the chain in the upper bar groove. Try to slowly rotate the chain CCW one complete revolution. Can you? Did the chain remain in the groove or occasionally ride up and out? Did it catch? If it remains in the bar without catching or riding up it is most likely a bad drive sprocket. Repost we can help with that too.
    Lou
    President:
  • 2,702 Answers
Yes it would,,,if the drive sproket is warn this is what is causing the chain to skip also have a close look at the bar try tipping the chain to one side if it tips at all the bar is warn out as well,,,dont do the chain up so tight that there is no lift left in it or you wear out the bar and sproket very fast,, there should be about 1/4 of an inch lift in the chain all round the bar onto just on the long strate parts chang that sproket fast?
I have a huscavarna 435 chainsaw and after running a few minutes the chain locks up
You may have the chain tensioner set a little too tight.
Additional things to check:
  • The sprocket on the end of the guide bar is greased, and turning smoothly.
  • The chain brake is working correctly (not dragging or only partially disengaging).
  • The guide bar is straight, not bent or twisted, burr free, and the groove the chain travels in hasn't been squeezed together.
  • The chain tension is set correctly.
  • The chain oiler is functioning correctly (and you have a sufficient amount and correct type of bar oil).
  • Chain is in good condition, and the correct one for the saw. Make sure all of the links flex smoothly.
  • Chain is sharp. A dull chain will put more pressure on the guide bar because the cutting teeth aren't digging into the wood efficiently (and usually a person pushes harder on the saw when the chain is getting dull).
Chain side tensioning
http://husqvarna.custhelp.com/app/answers/detail/a_id/590/kw/chain%20tensioning%20screw/related/1
Mar 21, 2016 | Husqvarna Chainsaw Model 435 16" inch bar
My Husqvarna 350 bogs down and is not turning the chain.
something is pinching the chain when you have the side cover on. either the bar isn't sitting flush to the saw or you don't have the chain in the sprocket correctly and that is causing it to bind
Jan 27, 2013 | Husqvarna Garden
Mine got dropped it will start but the chain want move . How do i fix it .
pull back on the chain bar lock , its the knuckle guard in front of the top handle.
Hope thats all it is?
Mar 06, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Bar & Chain combo interchange
A longer bar will allow you to cut larger trees easier but if you don't need to cut larger diameter trees and just want to cut faster you can get a more aggressive chain but use caution as you should be VERY experienced as the chain has the ability to pull you right into the work if you are not careful! Using a very aggressive chain should only be done by professionals with full safety gear.
Jul 31, 2010 | Husqvarna Chain Saw 18" 450 Model...
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Mar 31, 2009 | Husqvarna Forest & Garden No.967012396 345...
I can't find instructions for using the tooless chain tension
Bar/chain tension is generally controlled by a small screw adjuster... Basically you slightly loosen the nuts that are holding the bar onto the chainsaw, then turning the chain tension adjustment screw, this physically moves the bar outward from the saw, or inward depending on which way you turn it... When tightening, the bar moves outward away fromt he saw, in effect making the bar length slightly "longer" in regards to its position against the drive mechanism. This results in the chain on the bar being "stretched" and tightened against the bar as a result.
Hope that helps!
Mar 17, 2009 | Husqvarna Garden
Husqvarna model 345 chainsaw
adjust the gas by turning the screw on the carburator
Dec 28, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw husqvarna
Make sure the chain-brake is not on.
Take off the bar & chain & clean it. While they are off, check the sprocket is free to turn.
Check the bar is not pinched on the chain.
Sep 25, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
171 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
