Question about Canon imageCLASS D860 All-In-One Laser Printer
Paper jam!! gets caught in roller! help please!!
    Master:
  • Canon Master
  • 956 Answers
Remove jam, again. soft damp cloth, gentle wipe rollers at front, no hard pressure.
Continual jams usually are the result of purchasing cheap paper, I used to do the same, learn't lesson, only a few pence more, saves all the swearing and hassle of fiddling around with jams when you have more important things to be do?
Further tip, before placing quantity of paper in tray, holding paper firmly, twist in opps directions, this helps seperate the sheets of paper that may stuck together.
Posted on Nov 12, 2009
Testimonial: "thanks !! great work~"
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Paper jams in heater
Hello
An overheated fuser is one of the most common causes of a paper jam. When large loads of print jobs are pushed through a printer, the fuser slowly starts to warm up. As the fuser warms up, the heat causes the corners of the printer paper to bend. The hotter the fuser gets, the more the paper bends. Eventually the paper bends so much that it causes the paper to get stuck in the fuser, causing a jam.
If you cannot find any other reason for a continuous printer jam, the problem may be the roller. A cracked roller can easily grab a piece of paper and get it caught. A glazed-over or dirty roller can also cause the paper to get caught on the roller and jam the printer. If the roller is cracked or glazed, you may need to call your print technician or replace the roller.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | Ricoh Aficio CL7000DTL Laser Printer
I HAVE A HP 4345 THAT HAVE A PAPER JAM ERROR. THERE IS NO PAPER JAM. HOW DO I FIX THE ERROR?
If safety is not caught up paper, paper pick rollers probably replace worn or cleaned rollers
Oct 19, 2010 | HP Office Equipment & Supplies
The paper is not feeding through. it is getting caught on one side, then jamming
the roller on one side isn't picking the paper while the one on the other side is. Hwnce the uneven pull on the paper force the paper sideways and then jams.
This is usually caused by dust in the interior of the printer so try this:-
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, jam/crumpling results. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front; if you have a blower please use it as well). This, if properly done should do it. Brush especially the rollers etc.
Mar 26, 2010 | Canon PIXMA MP460 All-In-One InkJet...
It says out of paper "p" when there are lots of paper. And sometime it gets caught does not get fed. It's short of being jammed. If I open and close the paper tray a few time, it does the trick. what might...
Pull out the paper feed tray and (using a flashlight to look into the machine) clean the halfmoon feed rollers with rubbing alcohol on a cotton ball. The rollers are on the right side at the top where the paper tray fits in. If alcohol doesn't do the trick, try naptha (lighter fluid), if no success...replace the feed tires....just a thought. Let me know please...Tim
PS...if it doesn't feed paper far enough, it thinks there is no paper or a jam.
Nov 05, 2009 | Sharp AL-1642CS Copier
When we put paper in the printer it goes cricked
Lexmark printer have paper roller problem take printer for once service
Jul 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
HP 3210 getting paper jam because label stuck on roller.
I ran heavy card stock through printer several times, it caught the label and pulled it out on the paper eventually.
Feb 04, 2009 | HP Photosmart 3210 All-In-One InkJet...
Paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
Sep 27, 2008 | HP Photosmart C7180 All-In-One InkJet...
Paper jams
Make sure the feed rollers are clean. you can try alchohol or nail polish remover to clean the rollers (2). take out the paper cassette to get to the 2 rollers. check for piece of paper caught just out of cassette or around the turn to come out.
Jan 23, 2008 | Sharp AR-153E Copier
Brother MFC-9420CN Paper Jam B!!!
open and check for paper in the back. sometimes a corner may have been caught in there and will give you the error.
jb
Oct 25, 2007 | Brother MFC-9420CN All-In-One Laser...
Canon imageCLASS D860 All-In-One Laser Printer Logo
371 people viewed this question
old marine
old marine
