Question about Sony DAV-S300 System
Sony dav s-300 dvd.
My movies keep freezing half way through,with a error code of c:13:00...i tried to re-calibrate it but that didn't help....what can i do to fix the problem
  • Chris Skalski Feb 27, 2009
    I just get "no disk" when a clean, original, realativly scratch free DVD from that time period (like the 5th Element) is inserted in the drive. Now the motor spooled up once and sounded like a tractor. Anyone got one that DVD works but audio doesnt? I need a new DVD reader assembly I think.
    The calibration menu escapes me. I tried pressing muting and return while turning the volume knob. It's difficult to do so I dunno. Help.
  • Chris Skalski May 11, 2010
    Have you ever looked inside the thing? There are a thousand parts on top of the dvd lens. I am afraid to screw it up more, and I have fixed DVD units before by opening/cleaning in the way suggested. Need direct instructions for this unit. What do I really need to take off and check and what will pop off and fly 50 feet accross the room due to spring loading and down my kitchen drain, never to be reasembled and resulting in a Simpsonesque "Angry Dad" smashing of unit and tossing it in nearest dumpster. Need more help.
    Genius:
  • 1,175 Answers
Is the unit old enough to have some room dust inside fowling the DVD laser lens?
If open the case doesnt scare you then ..UNPLUG it from the AC outlet,remove the outer case screws and use some compressed CO2 on the DVD assembly. Spray at a distance of 8-10 inches.
If you can access the lens on the player, VERY lightly clean it with a swab of Isopropyl alcohol.
Most of the units I get with bad read problems get fixed that way
Posted on Jul 07, 2008
6ya staff
SOURCE:
I want to update my Sony DVD Player DAV-DZ10 Divx Drivers to run recent divx movies, can anyone help?
Nov 14, 2010 | Sony DAV-DZ100 System
Home cinema sony dav f200 error cde c:13:71
ive got a sony dav f200 home cinema system,it lets me play music cds but trying to play dvds(not copied or american) it comes up with and error code c:13:71. what does it mean?
Mar 14, 2009 | Sony Televison & Video
Dvd freezing
is ur dvd player in an inclosed area because they need air and some more than others. is the device getting hot to the tuch. if it is then put somthing under the corners of the dvd player to raise it up. this should stop it from over heating. also try cleaning it. please rate my suggestion. thanks
Feb 01, 2009 | Sony DAV-DX150 System
Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty)
i had the same problem, first when i burn movies i was using fujilim dvd+r after 10 movies burned i use maxell dvd-r i burn just 3 movies then i had a error (Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty) after doing a lot of things to fixed and research thounsands of webpages one told me to use a diferent dvd then i buy sony dvd+r and now everything work perfect, maybe it helps, write me if you need help.
[email protected]
Jun 20, 2008 | Toshiba Computers & Internet
DVD freezing up
It very well could be a lens problem.
When the laser is in a desperate search for more data, it can max out the whole unit trying to find it. Same thing will happen with a PC's dvd drive if you put a dvd in and it is scratched or damaged.
The lens in your unit may not be dirty, but it may need to be calibrated again. Knocks in transport, dust, bugs, general use etc etc can all have an effect on the laser.
The fact it's doing it in a cycle could also be heat related. Again this goes back to the calibration. If the laser is working far harder then it should, it will heat up and begin to fail.
Since it is only a few months old though, I would call in on the warranty to have it looked at without causing you further grief.
Apr 30, 2008 | Sony DAV-IS10 System
Movie freezes, skips.
Does sound like the laser. Realitically, not worth repairing. I'd say you'd be worth connecting a cheap DVD player to the system - then the Sony can carry on providing the surround sound audio and the new DVD player can provide the video. Then, if the cheap DVD player is still going, it can move to a bedroom TV if and when you replace the surround system....
Otherwise, I would imaging the speaker set (and even the non-working DVD player) on its own might fetch a reasonable price on an auction site - anyone who has a stolen DVD unit will probably be desparate for the speakers as Sony don't sell them separately!
Jan 04, 2008 | Sony DAV-S500 System
Dvd pauses
mY DAV-C770 has the exact same problem ...when watching a movie it will intermittently pause or freeze ...then continue. It will do this 20 or 30 times throughout a movie. I asked a tech at Sony for help and he told me the laser reader is out of alignment. The minimum amount to have the dvd player sent out and repaired is $200.00, and thats if it does not require any parts. with a new laser reader it will be about $400.00. Almost the same price as a new dream system. Not worth fixing. I used to think really highly of Sony - until now. Jackal
Nov 21, 2006 | Sony DAV-C770 System
Sony DAV-C700 dvd player not responding
take it to a authorised technician and get the lens reading circuit replaced it will work
Jun 12, 2006 | Sony DAV-C700 System
Sony DAV-S300 System Logo
461 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
