Question about Fisher and Paykel GWL11 Top Load Washer
My f/p wont drain. the washer called ecosmart
Ours wouldn't spin or drain...Unhooked hoses and power pulled it away from wall and tipped it back and looked underneath. A dryer sheet had wrapped around the little fan shaft on pump. Cleared it now it works fine.
Posted on Nov 29, 2009
  • 441 Answers
Your pump is jammed, call 1.888.936.7872 they will be able to walk you thru fixing it
Posted on Nov 12, 2009
Fisher and paykel ecosmart 96193-a wont drain
Fisher and Paykel might be able to supply a repair manual.
May 20, 2014 | Fisher Paykel EcoSmart GWL15
Ecosmart washer won't drain it filled with water, washed and nowwon't drain the water.
you need to vacume out all the water so you make it light, then dolly out the washer to some place you can drain it. now take off the front of the washer and locate your water pump, its attached to your drain line. take off drain line to water pump and see if anything is clogged in the pump. This is most likely what is wrong if it wont drain. hope this helps.
Feb 22, 2013 | Fisher Paykel EcoSmart GWL15
Fisher and paykel gwl15 wont completely drain
Also check the clear pressure tube for blockages,
Blow air down the pressure tube to remove any blockages
that would prevent water level from changing.
Jan 02, 2012 | Fisher Paykel EcoSmart GWL15
My washer wont drain and when i try to start it over nothing happens. last time i was able to drain the water but when i put in another load, the washer filled with water and wouldnt drain again. Help what...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Fisher Paykel EcoSmart GWL15
Not lit up to show power
You may have overloaded your washer. Some washers have a safety trip feature that activates when the motor is overloaded. Try unplugging the washer and removing the clothes. Once you have done this, go ahead and start the washer again. If you that doesn't work, you made need to check if you have blown an internal fuse or call a qualified technician. I hope this helps. Good luck.
Jul 23, 2010 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Washer won't drain and some cycles won't work
Make sure your drain hose is at least 2ft off the ground if your drain pipe is to low it wont drain
Feb 18, 2010 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
The washer wont drain
Check clear filter //pump
Sep 29, 2009 | Fisher Paykel EcoSmart GWL15
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
Feb 07, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
193 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
