Question about Texas Instruments TI-83 Plus Calculator
Big problem I go to turn on the calculator but the screen will only show up sometimes and it will flash on qiuckly then turn off. I don't know if it was wrecked but I was wondering what you could do to make the screen appear and the calcualtor work. I have installed new batteries too. Thanks
  • 1 more comment
  • clacman305 Jan 16, 2008
    i turn on my ti-83 it says mem cleared and then turns off please help me!!!!!
  • asdflkj Jan 22, 2008
    HOLY FUCK same problem
  • ej90143 Jan 24, 2008
    the smae thing happens to me it turns on for a second the srcreen is black then it turns off i tried new batteries but nothing happened
That is the exact same problem for me!
Posted on Jan 15, 2008
SAME PROBLEM FOR ME! sometimes it shows a bunch of wierd random numbers and symbols and it wont let me do anything but then it goes away and wont turn back on .. have installed new batteries and tried the one battery reinstall trick w/ the clear and on buttons.. no luck PLEASE HELP
Ti89 responds to resets but nothing else
If the calculator is several years old it may be showing its age.
There is a connection point between the keyboard and the display
that over time loses its efficiency. Try this: press a number key
and at the same time apply pressure with your thumb or index
finger to the region of the calculator just below the display.
If you press hard, the number may just show up in the display.
This is a test for the tightness (or electrical efficiency) of the
keyboard-to-display connections.
Another way to make this test is to twist the calculator while
you depress a number key.
Sometimes the effect is such that the keys on one side or the
other work, or don't work, and the keys in the middle don't work
or work okay. By twisting (don't break it!) the calculator body
while you press the keys will show the weakness of the
connector between the display and the keyboard.
This can be repaired by a good electronic technician if you
explain to him what I just told you.
Aug 29, 2011 | Texas Instruments TI-89 Calculator
TV is on standby and turning it on goes green then a few seconds later the screen will qiuckly flash and go back to stanby so it will not turn on
indicating over current shut down. Depending on brand and model, power supply troubleshooting will aid you in repair.
Feb 18, 2011 | Televison & Video
My touch screen is not working. after a long time
if you kept the batteris inside for long time it could be that they leaked inside when it happend there is some damage inside.
update for the OS sometimes helps
i fix this calculators
ecrdn@yahoo.com
Sep 25, 2010 | Casio ClassPad 300 Calculator
Qiuck orange flash light when i start my dell pc
that means that its has problem recieving power or a power supply could be going out soon make sure it is plugged in directly to the wall outlet on no power strip or multi-outlet.Check the black power cable in the back computer . Make sure its tight in there.
May 14, 2010 | Dell Dimension 4700 PC Desktop
I turn on the calculator and the screen just shows me this like big dark box that fills the screen and thats all it does.
After you change battery the screen contrast often changes: it can become too light or too dark (your case).
To lighten screen
  1. Press 2nd key and RELEASE IT.
  2. Press and HOLD the downArrow.
  3. Keep pressing the arrow until the screen is light enough.
Jan 13, 2010 | Texas Instruments TI-83 Plus Calculator
The calculators screen is not fulling showing the
Hello
If it is too dark
Try reducing the contast as follows
1.Press [2nd] key and release it
2.Press [DownArrow] and release it
3. Keep repeating the sequence until contrast is adequate.
If it is too light increase contrast
To increase contrast Do the same but press [UpArrow] instead of [DownArrow]
Hope it helps
Sep 07, 2009 | Texas Instruments TI-83 Plus Calculator
My calculator works fine but recently when I use it the screen is very light. I already have it on maximum darkness and sometimes it works but occasionally the screen flickers?
When screen is at maximum darkness you see almost nothing.
Here how you change screen contrast (just in case another readed does not know how to do it).
To increase contrast:
1. Press [2nd] key then release it
2.Press [UpArrow] key then release it.
3. Repeated steps 1 and 2 in sequence, until contrast is dork to your taste.
To decrease contrast:
Follow the algorithm (a very big word for procedure) above substituting [DownArrow] for [UpArrow].
Hope it helps.
Jul 17, 2009 | Texas Instruments TI-83 Plus Calculator
Sharp 2DR-S100S Ticking sound, will not turn on
does it tick all the time are just a few minutes and can you turn it off and back real qiuck and see or hear high voltage come on are see a flash is sounds like you have what is know as startup are shutdown circuit trouble
Feb 22, 2009 | Sharp 25R-S100 25" TV
Texas Instruments TI-83 Plus Calculator Logo
346 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
