Question about HP 1050 Plain Paper Inkjet Fax
The screen say to adjust scanner first in maintenance???
Maintenance required code TA
This is a scheduled maintenance error. It can be reset, but if you see it on the screen you likely need some preventative maintenance. If you're in the Houston, TX area we'd be glad to be your servicing dealer.
Feb 24, 2014 | Sharp MX-4111N Copier w/ 36 Month Warranty
Sharp MX4100 maintenance code vk
Check out this little walkthrough I have put together. Adjusting the printer port settings on your computer should take care of it. Sharp Printer Offline Solution
Feb 20, 2014 | Sharp "MX-4100N Copier, Printer, Scanner...
Shaded area on white scanned papers
Go through the printer properties (control panel/printers/right clicking on the printer, and click on properties). Then go to the maintenance tab and click on clean print heads.
Apr 30, 2012 | Fujitsu fi-6130 Flatbed Scanner
Hi, Have a Kyocera KM4050 copier/scanner/printer with a touch screen. The touch screen is out of alignment (i.e. where you point does not align with what is sensed by the touch screen) and needs...
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine.
To get into maintenance mode do the following:
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key.
2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Feb 09, 2011 | Kyocera CS-2050 Black and White Copier
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
CANNOT GET INTO THE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
Once you press menu #1934 you have to then press the machine status button then scroll to maintenance, then scroll to clear memory. Once you do that repeat entering the tech mode, press machine status, maintenance and perform a shading adjustment with 5 pieces of paper on the glass, that will recalibrate the scanner.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
Have a Xerox M20i. Copy comes out light. Toner should be OK. Prints fine. Scans fine.
You need to clean the scanner. You can try doing the shading adjustment to calabrate the scanner but most likely the mirrors are hazed up. Since you can print fine you eliminate the laser.
To do the shading adjustment, you need to press in order,,, Menu # 1934, You will see a " T "on the screen, that will be the tech mode. Press the machine status, then go to maintenance, then scroll to shading. Place 5 sheets of white paper on the glass and then run the shading adjustment. turn the machine off and on, and run copies again. But most likely you will have to take the scanner off and clean it.
If you want to clean the scanner let me know, I will send you directions on how to do that. The mirrors in that scan head tend to haze up.
Jan 06, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Very Light Print
What you need to do is adjust shading. That recalabrates the scanner. To enter the machine into the tech mode you press " menu, # 1934" then you will be in the tech mode, a T should appear on the machine screen. You then go to machine setup and maintenance, then scroll to adjust shading or just shading, depending on how your specific firmware states it.
Then place 5 sheets of white paper on the glass, 5 pieces of paper think not spread out, then press start, if it askes you DO you want to asjust press start and let it run through the setup.
Once you have cleaned the scanner you really need to adjust teh shading. A better way to say it would be scanner calabration.
Oct 17, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Light copies
You enter the buttons in this order. " menu" " pound" 1934, the machine will come up with a T or tech on the screen, you have to then press the machine settings button then scroll to maintenance, press enter, go to adjust shading, place 5 white pirces of paper on the glass and run the procedure.
I doubt though that without removing and thoroughly cleaning the scanner that it will work properly. Those mirrors and the glass haze up badly and need to be cleaned to clear up copy quality.
to remove from tech mode once you do shading. Just POPO the machine. ( Power Off Power On )
Jul 18, 2008 | Xerox WorkCentre M15i Laser Printer
Copying spreadsheets
If the lines look like little steps, maybe broken is segments off by about the thickness of a pencil line, try this. Most likely it's the scanner. You can try calabrating it by doing the following. press in order. Menu #1934. You will see a T pop up to the right side of "Ready to Copy". Then press machine status, then scroll until you find maintenance. May be under system settings. When you find maintenance, press enter, then scroll to Shading Adjustment. Or depending on software version, Adjust shading. Place 5 sheets of paper on the glass,, press enter, then when is says "Adjust Shading?" press enter again. Let it print out the sheet. Then try a copy. If that doesn't help, the scanner itself will probably need replacing.
The scanner is the issue. The segments of what is called the CCD are not working properly.
Once you adjust shading, if that doesn't work, the scanner will need to be replaced.
Feb 28, 2008 | Xerox CopyCentre C20 Black and White...
HP 1050 Plain Paper Inkjet Fax Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
