Question about Northstar 952 GPS Receiver
Northstar 957 ser # 95700042 unit shuts down during operation if boat pounds. are parts available thank you Rob Kalbacher
  • 1 more comment
  • kalbachers Nov 12, 2009
    emissionwiz
    Northstar factory answered that no parts are available for the 957 any suggestions
  • yadayada
    yadayada May 11, 2010
    then u are through here, sorry.
  • yadayada
    they don't sell parts to the user, it can only be repaired at a factory repair center.
2 Suggested Answers
jackiaria
  • 350 Answers
SOURCE: Northstar 951 GPS shows boat moving & @ high speeds (over 100)
RE: Northstar 951 GPS Receiver
Contact & Support @ http://www.northstarnav.com/en/Support/
jack
0501102.jpgPlease Rate This Now or Later!
Posted on Feb 22, 2009
I have 1997 Cadillac Deville 4.6 v8 Northstar 32 valve it has 90 pounds fuel pressure an it should have 40 to 50 pounds why is the fuel pressure so high?
Fuel pressure regulator . plugged fuel return line .
With the ignition switch ON and the fuel pump running, the fuel pressure indicated by the fuel pressure gage should be 333-376 kPa (48-55 psi).
The Fuel Pressure Check determines if the fuel system is providing fuel pressure. The components involved include the fuel tank, sending unit, pump, pipes and hoses, pressure regulator, fuel rail, and injectors. Also checked is the electrical operation of the fuel pump relay. This chart requires J 34730-1A , Fuel Pressure Gauge J 37287 , Inlet and Return Fuel Line Shut-off Adapters.
Feb 18, 2017 | Cadillac DeVille Cars & Trucks
We have a Northstar system on our boat...the M121 and while out fishing today the screen went so dark we cant read it without a flashlight. Cant seem to be able to fix it either..any ideas?Thank-you
i have the same problem there is a resistor on the high voltage side burned cannot identify the number or resistance to replace it need diagram or parts list for machine
Jul 30, 2013 | Northstar M121 Navigation System
Generator runs for about 10 minutes and then stops like it is running out of fuel. 5500 NorthStar with Honda motor. Waned fuel tank and lines, had carb. Rebuilt and cleaned all out with carburetor cleaner....
It appears you have eliminated all of the fuel related issues. That would leave the generatoor safety circuits as a possible reason for the unit shutting down.
The Low Oil Level Sensor is the major reason that generators shut down when your sure there is not a fuel supply problem. Make sure the unit is fully servied with OIL. If the problem persists disconnect ONE wire from the low oil level sensor and see if the problem persists. If you still have the problem inspect the black or green wire from the Start run switch all the way to the Air shroud on the engine looking for signs of chaffing.
If you can not find anything then you will have to re-focus your attention on the fuel system once again. If you have a solenoid on the base of the carb.. the solenoid can be WEAK and stop remaining open once hot. This will cause the engine to lean out and die.
You should also check fuel flow to the carb. The flow should fill a spary paint can lid in under 10 seconds to the point your worried about it overflowing. Most honda engines have a metal sediment bowl under the fuel selector. Remove the sediment bowl and dump the contents. Check fuel flow again.
- Carb. With the float bowl removed fuel selector ON check fuel flow again by holding a spray paint can lid under the float. It must fill up in about 10 seconds to the point your worried about over-filling the lid. If you do not have a good flow rate here the float needle float needle rubber seat and the fuel manifold are the prime suspects.
I know this generator has the Honda GX270 engine. Some have solenoids (Item 49 this link)
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE,%20JPN,%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CARBURETOR%20(2)/parts.html
^- No details!
Honda engines by model and VIN can be found here:
http://www.boats.net/parts/search/Honda/Engine/0/parts.html
At this time I think the low oil level sensor (sending uint) may be the culprit causing your problem.
Item 2 this link:
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE%2C%20JPN%2C%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CYLINDER/parts.html
Thanks for choosing FixYa,
Kelly
Sep 16, 2011 | Electrical Supplies
Hello, I have just bought my Bavaria 36 in the netherlands. We have sailed her to Sweden a few days ago. The boat is equipped with a chartplotter RayMarine RC 435. During our trip we noticed the folowing:...
One thing you might check is for any corrosion in the 12VDC power cable at any point on the way to the unit. If the wires are somewhat corroded they will heat up as the unit draws power and the inherent voltage drop a from heated wires may lower the available voltage to the unit so it shuts down.
Jun 20, 2011 | Raymarine Rc435 Chartplotter
SImple question...I appear to have lost the protective white cover piece that slips over my Northstar Fishfinder unit (may have blown off when boat was in transit. The unit is a Northstar 438 fishfinder...
Check ebay for a new/used cover, or an oem product that will perform the same task. If this doesn't help, check with the company itself, they might have one for sale.
Mar 03, 2011 | Northstar Norhtstar Explorer 438 Display...
Gps will not aquire
It needs a software update.
Jul 01, 2010 | Northstar 952 GPS Receiver
Hobart electric convection oven model #cn90 ser. # 07-007-968-nj
Have you tried shutting down all power to your oven at the electrical panel, waiting 10 minutes and then returning power to the unit? Procedure could reset the defaults. Best of luck.
Apr 09, 2010 | Hobart HEC501-240V Electric Oven
jack
Feb 22, 2009 | Northstar 951XD GPS Receiver
Neptune mah5500bww
I've had the same problem with a Neptune MAH3000. I replaced the mother board to no avail. I replaced the timer control to no avail. I then replaced the door lock assembly (wax motor, door switch, etc.) and problem solved. Luckily, I had another machine that I could rob parts from.
Nov 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
Northstar 952 GPS Receiver Logo
100 people viewed this question
Top Northstar GPS Experts
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
