Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Re: my double dishwasher, in additon to the F1, I
Re: my double dishwasher, in additon to the F1 sybols on both top and bottom, I can't get the unit to go to wash it is stuck at rince, although the wash cycle was complete. P.S. there is no water at the bottom of either unit.
  • Fisher and P... Master
  • 3,247 Answers
One possibility is that the filter area in both the drawers is dirty. In case you have not cleaned the filters before, then follow the steps in the user guide on cleaning the filter plate and the things underneath including the motor cavity.
Also I find using the dishwasher cleaner (in powder form one packet per drawer) is helpful. Follow the instructions on the cleaner packet.
Good luck
Posted on Nov 15, 2009
Flood switch 920 model
Not sure what the actual model number is but usually the F1 error with Fisher and Paykel dishwasher means water has entered the flood switch located at the base. This could be due to leaky hoses or water leaking through the door or lid seal. Wait for a day or two until the water evaporates and try again. Otherwise you will have to dry out the flood switch and then try again. Location of flood switch will depend on your model. For double drawer dishwasher you will have to take the bottom drawer out from the housing and the switch is on the floor of housing. But make sure you take the mains power chord out before touching the insides of dishwasher. Will also need to find the cause of the leak. Other reason for F1 could be loss of power to top dishdrawer if you have double drawer. But in that case the top drawer will have no lights on. The power board is located on the base of housing under bottom drawer. Once again do not touch inside of dishwasher without shutting off mains power.
Jan 27, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fischer and paykel drawer dishwasher has no power to drawer, power at outlet, was flashing F1 prior to shutting down, thanks
If you have a double drawer unit then please confirm what is happening with the other drawer. Most likely the base of the dishwasher under the bottom drawer has flooded and brought down the power with it. The power board sits under the bottom drawer. BE CAREFUL NOT TO TOUCH THE DISHWASHER BEFORE SWITCHING OFF THE MAINS POWER SUPPLY TO THE DISHWASHER AS THE CIRCUIT MAY BE LIVE AND GIVE A SHOCK. You will have to take the bottom drawer out and see what is happening under it.
Jan 16, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code on my Fischer Paykal drawer dish washer . This is the flood sensor . It was. tripped when water was splashed in a plug that shares the same Circuit. How do I reset the sensor?
Not sure if the flood sensor will trip if the water is splashed into the mains plug. F1 can also occur if the power to the top drawer has failed. Flood sensor trips when water collects at the base of the dishwasher housing under the bottom drawer.
I think the problem you mention has caused the power to the top drawer to fail due to a spike when the splash on the power plug occured. This is very easy to see. Check if the display on top drawer is blank.
Nov 04, 2012 | Fisher and Paykel Dishwashers
Have an f1 error that comes up , says it is a flood switch doesn t seem to be any water in the area around the dishwasher. Any ideas?
The flood switch is at the base of the dishwasher housing under the bottom drawer.
Do you have the F1 fault displayed in both drawers? If so, or if you have single drawer, then turn power off and take the bottom drawer out. Dry the base with towels and use hair dryer on the small circuit board at the base.
Put everything back and turn power back on. The source of leak could be lid seal, kink in hose or ruptured hose.
If you have 2 drawer unit and the F1 error is in top drawer only then the bottom drawer has lost power. Could be due to thermal fuse blown on heater plate.
Hope this helps find the problem.
Dec 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 error
The heater unit in the bottom drawer is blown. This causes power to shut off to the controller. The effect of this is the F1 error on the top drawer.
If you get the heater on bottom drawer fixed, that should take care of the F1 error in the top drawer.
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
DD603 Does Seal need replacement? F1 Error Code
F1 error code appears because moisture has been detected by the flood switch on the base of the housing under the drawer.
If you think the door seal was not fitting properly then that too can cause moisture leak into base of the unit where the flood switch is located. Steam condensation would also lead to moisture.
Best option might be to replace the door seal for the top drawer. This is not a trivial thing as the unit has motor actuated door seal which can be tricky to fit back in.
Also avoid foaming in the detergent by using the correct powder and not tablets.
Please rate this solution if you are satisfied otherwise post a comment.
May 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom unit does not always seal and causes water to collect in bottom pan which throw unit into f1 status. Sometimes it stays sealed and is difficult to pull drawer out. Is there a way to reset the unit...
These dishwashers are very sensitive to grime collecting around the drawer edges. Try cleaning with a damp cloth by rubbing along the top edges and the sides where the drawer door sits flush with the body.
Also trun off power at the mains and then turn back on after a short wait.
Oct 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
146 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
