Question about Braun Silk-epil 3370 Epilator
Epilator head won't spin but the spinner below the head (which can be detached) is spinning just fine!
Emjoi light caress epilator jammed
The major reason that epilator shavers stop working is because of hair that is caught inside the machine. If you have taken the top off and cleaned it out thoroughly using the brush, then this likely isn't the cause.
Is it still under warranty? if so, i suggest that you contact the manufacturer and ask where you can send it for fixing. if your warranty has run out, you can still ask the manufacturer for a list of approved repair shops.
Feb 26, 2013 | Emjoi Light Caress Gold Corded Epilator,...
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
BonJour 3450-70 Fresh Spin Automatic Salad Spinner
how do you put the lid together just below the area of the top? Friend went to wash spinner and pulled on top and now I can't get it to sit flush anymore. It seems there a two plastice prongs inside top that must be released. Help please. Love this spinner but now can't use!
Nov 18, 2012 | Washing Machines
Drum seems off balance....
You likely have a corroded/broken spinner assembly on the back of the inner tub. If your washer is out of warranty it is usually cost-prohibitive to repair. We usually quote about $350-$400 parts and labor for it. If you can wiggle the inner basket relative to the outer, that confirms a broken spinner.
Apr 20, 2010 | Frigidaire GLTF1670A Front Load Washer
The ps2 works fine, but when i try to play a game, it doesnt sense the cd. it doesnt even spin. anything i could do?
barely put any oil where the spinner and ps2 are connected on the top, but clean the oil off. if that doesnt work your motherboard might have chipped at where the spinner usually spins at.
Dec 09, 2009 | Sony PlayStation 2 Slimline Console
I put the game in but the disk does not spin
try cleaning the spinner and laser and make sure the spinner and game make contact to where they spin. it might be that your tray is kind of crooked and it misses the spinner to where the game wont spin.
Dec 08, 2009 | Sony PlayStation 2 Slimline Console
Head wont spin but spinner below it is working fine..
is this a rotary shaver if so the plastic gear is broken or worn out
Nov 12, 2009 | Health & Beauty
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Oct 20, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Are there any replacement heads out there?
If you go to http://www.jr.com/emjoi/pe/EMJ_AY5S/
they have your razor and it's a rechargable one for only 34.99 plus 6.99 shipping but you might want to check out that sight
Apr 16, 2009 | Emjoi AP98R Epilator
The spinner gets off balanced make knocking sound
Ok first is it a top load or front load and I need the model number inside the lid or door.
Sep 23, 2008 | Kenmore 24032\24036 Top Load Washer
Braun Silk-epil 3370 Epilator Logo
397 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
Robin Hill
Robin Hill
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
