Question about Hotpoint Ultima WF865 Front Load Washer
Cycle does not finish door wont open error code f05
  • Hotpoint Master
  • 3,463 Answers
F05 means pressure/\waterl level switch is jammed on full.
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Please leave feed back
Thanks
Posted on Nov 13, 2009
Hi - my washing machine keeps f05 coding & the green start light won't come on
Is the outlet pipe blocked. Check this as sometimes the water gets backed up and this is sensed and an error is displayed
Mar 28, 2015 | Washing Machines
Door remains locked after wash, no error code or anything.
if there is water left in the machine it will not open pull out the washer if under work top tilt the machine back wards the door should open thwn clean filter and try
Dec 02, 2012 | Washing Machines
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
Sep 30, 2011 | Washing Machines
Two of the baffles broke replaced them now getting a code f05 and washer beeps and wont finish wash cycle
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
Above is your service manual, look in the area of the NTC sensor,it needs to be replaced, the service manual will show you how.
You need to replace the ntc sensor, most likely.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Hi, my ultima machine door wont open and says error code f-05, can you help.
Link to the service website: http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
From the owner's manual under troubleshooting:
Error code: F05 - Pressure switch jammed on full
The door will not open...
● Has the programme finished? Is ‘End’ lit
in the display window and the ‘Keyhole
symbol deactivated?
The door will not open until the ‘Keyhole
symbol goes out shortly after the
programme has finished.
● There is still water in the machine.
Go through all the points in the next
section,‘The machine will not pump out
water...’
The machine will not pump out the
water...
● Make sure that there is no blockage in
the drain hose and that it is not kinked.
● Is the drain hose installed correctly?
● If you have connected your machine to a
sink waste system, make sure that you
have cut out the membrane from the
under sink drainage system.
(see section: INSTALLING YOUR
MACHINE).
● Ensure that the drainage system,
standpipe or under sink connection is
free from any blockage.
- If any of the above are found to be
the cause of your problem you will need
to run the machine through a spin only
programme.
● If you have chosen ‘Rinse Hold’, the light
will flash until you press the ‘Rinse Hold’
button to continue the programme.
Jan 16, 2010 | Hotpoint Ultima WF865 Front Load Washer
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error codes
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Nov 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
166 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
