Question about Sony Cyber-Shot DSC-S60 Digital Camera
After inserting memory stick and powering it on DSC 60, error reported in Memory stick error" How can I upgrade firmware for dsc 60?
SOURCE: DSC-F717 "Memory Stick Error"
I had the same problem and fixed it by formating my memory stick on the camera that had the problem. It still didnt work but then I took the memory stick to another sony camera and formated it on that camera then placed it back in the camera that didnt work and it worked. Dont know why or if it will keep working but i dont get the "no memory" anymore.
Posted on Jun 13, 2008
SOURCE: DSC F707 Error C:13:01
If you really have a F707, it won't work with anything over 128MB according to this chart.
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCF707#m1
Posted on Aug 11, 2008
  • 586 Answers
SOURCE: Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
Posted on May 24, 2009
SOURCE: Memory Stick error
Hello!
Following types of memory sticks are compatible with the Camera model DSC-V1:
Memory stick: 32/64/128 MB
Memory stick Pro: 256 MB/512 MB/1 GB/2 GB.
Mark 2 Memory stick Pro: 1/2 GB.
However, in order to use Memory Stick Duo or MagicGate Memory Stick Duo media with the Camera, a dedicated adapter (MSAC-M2) must be attached.
Follow the steps given below to troubleshoot the Camera that is not recognizing any compatible memory sticks:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
Furthermore, you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds.
If the issue persists even after performing all the above mentioned steps then the Camera is required to be diagnosed and serviced.
Posted on Aug 23, 2009
hichama9
  • 65 Answers
SOURCE: have a DSC-S930 camera inserted my memory stick
Hello Mate,
you may double check how you inserted the memory stick, it may be in wrong position.
other than that, you can insert this memory stick into your computer and see if you can open it from there. and you can also format it from your computer and then test it again with your camera.
Best Regards,
Posted on Oct 31, 2009
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Reinsert memory stick --- I have removed battery and memory stick with no result. Help
Sony says:
Article ID : 101488 (modified 10/29/2009 03:18:00) Question: A warning message appears on the LCD screen when a Memory Stick is inserted into the camera. Answer: The following could be possible causes for the error message to appear:
  1. Verify that the Memory Stick is inserted correctly.
  2. The inserted Memory Stick cannot be used in the camera. Refer to the related link below for compatible Memory Stick.
  3. The Memory Stick is damaged.
  4. The terminal section of the Memory Stick is dirty.
http://www.sony.com.ph/support/faq/101488/product/dsc-w190/modelfirst
Jan 02, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
I purchased a Sony cybershot DSC- S930 and inserted the Lexar memory stick (supposedly compatible with a sony camera) and upon turning the camera on there is an error message stating there is not internal...
The camera does not recognize the card because
1. Card not compatible
2. Camera cannot handle such a large capacity.
3.Card not inserted correctly.
Maybe a recent firmware update can address the 2nd limitation.
Hope it helps.
Sep 11, 2009 | Sony DSC-S930 Digital Camera
I GOT THE PROBLEM IN MY CAMERA FORMAT ERROR C:13:01 MODEL DSC-P31 THE PROBLEM CREATED WHEN I TRYIED TO DOWNLOAD PICTURE
The Error message C:13:XX indicates that the Camera cannot read or write data on the Memory Stick or an unformatted Memory Stick is inserted in the Camera or the inserted Memory Stick cannot be used with your Camera or the data is damaged.
1. Try reinserting the Memory Stick several times.
2. Format the Memory Stick in the Camera.
*Formatting a Memory Stick will delete all the data saved in the Memory Stick.
Insert the Memory Stick in the Camera, Turn ON the Camera. Press MENU -> Memory Stick Tool -> Format -> OK.
Memory Stick compatibility information for you Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCP43
3. Try with different Memory Stick.
Good Luck!!!!!!!!!!!!!!!!!!!!
Aug 28, 2009 | Sony Cyber-Shot DSC-P43 Digital Camera
DSC-W70 doesn't recognize full capacity of (Sony) 8GB Memory card
DSC-W70 hardware does not support 8GB memory stick.
Please use maximum 2 GB memory stick in this camera.
Jul 30, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Memory sticks "MEMORY STICK ERROR" for SONY DSC-S30/S50
this camera doesnt take mem stick pro. has to be the original lavender sticks.msh-ms128 is the model # only goes up to 128 mb. only stick that will work with that cam.
Jun 01, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
memory.
CAUSE :
unformatted.
May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
INSERT ANY NEW MEMORY STICK SHOWING FORMAT ERROR
Please format memory stick by camera Menu >> Format option.
If problem still exist, try another memory stick and check camera again.
Apr 25, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Memory Stick File Error
Could be that the camera does not support a 2G stick. Check the operators manual.
Aug 31, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cyber-Shot DSC-S60 Digital Camera Logo
23 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
