No power could be cord but cannot undo bottom screws they seem to be seured therefore cannot see if cord loose. Do the screws come off or do I take it to a dealer Euro Touch Microwave Sanyo
  • 460 Answers
Best to take it in for service..
Posted on Nov 12, 2009
Broken power cord inside Conti Twister vacuume. I cannot find how to open the motor to get at the broken cord.
without seeing it i can only guess.... but most motors require taking all the screws out of the vac and prying the halfs apart... sometimes you can get away with just doing the panel at the bottom by the hinge where the handle pivots( depending on model.... to get the motor itself apart.... if there arent any screws to take out tben youre prettymuch out of luck.... you need to see where its held togethrr and undo it.
Nov 08, 2013 | Vacuums
Trying to undo the cord thing and it just keeps turning and won't come off
To insert a new cord, hold the round plastic container where the nylon cord comes out so it stops turning, then you can unscrew the bottom part of the plastic holder (retaining screw). The cover and inner reel will come off so you can wind new nylon cord onto the reel. Insert the ends of the nylon cords into the outlet holes and replace the cover and retaining screw.
Oct 04, 2012 | Garden
Our magellan keeps turning off. the plug seem loose. could it be the cord or is it the battery and can it be changed
Check your power cord. You may be losing power at the plug. When plugged in it may be losing contact with the recepticle. The power indicator light initially comes on but, breaks contact and therefore stops charging the unit. If this is the case you can sometimes plug into an adapter and get a tighter fit.
Apr 25, 2011 | Magellan Roadmate 1200 Car GPS Receiver
I have a model WM2688HNM LG Washer and have a TE code. I would like to get a repair manual to show me how to open the cabinet to get directly to the thermistor to check for a loose or broken wire.
undo the screws at the back take the lid off then pull out the dispenser draw take two screws out holding front display on then jiggle the display out might be lugs or clips holding it in place as well then take the bottom kick plate off lever it with a flat blade screw driver it just pops off then open door take door lock screws out then take spring off the door gasket then undo the screws on the top & bottom of the front panel then your in
Jan 05, 2011 | Washing Machines
Presario cq70 my screen keeps tippling really fast and the only way to try and correct it is to keep moving the screen lid into a different position what could be causing this
You would seem to have a loose connection, if you undo the screws on the front of the screen then check your connetor which should be at the bottom and might just need pushing back together.
Sep 03, 2010 | Compaq Presario Notebook
Cannot undo nut on bottom of Strimmer
Make sure you are turning the nut to the right to loosen, if you are already doing that but cannot hold the line head still to loosen the nut some feature a hole to insert a screwdriver or pin (supplied with the trimmer) or if yours does not have that: use a nylon strap or even a leather belt to wrap around the head, and then clamp the loose end in a vise or quick clamps and it will hold it in place well enough to loosen the bolt.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Rowenta Iron-Professional Luxe The power cord seems to short out when you move iron. You can wiggle it next to the movable ball and it clicks on and off. The two screw heads on bottom appear to be special...
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Oct 22, 2009 | Rowenta Irons
Replace dispenser arm
on the bottom of the ice dispenser front cover is 2 slots insert a small screw driver into these slots and carefully pry the cover off (be careful not to scratch your door) one the cover is off there will most likely be a wiring harness that you can unplug and put cover out of your way. next you will need to move the white bracket out of your way there is either 2 thumb latches or 2 screws that seure it. it will not come all the way out so you may need someone to hold it out of the way for you. in the center of both of your levers you will see 1 screw with a cardboard spacer and brass spring BE CAREFUL NOT TO LOOSE THESE! remover screw spacer and spring afte that you should be able to work the levers right on out. the ice lever is a little tricky trying to get it around the ice door but it will come out.
Jan 31, 2009 | Refrigerators
Starter cord has detached internally and I cannot get to it
Depending what make and how old the machine is,usually there is a torx screw in the middle of the clutch drum(metal part that rotates).you will need to use a piston stop,to stop the engine turning while trying to undo the torx screw. i am assumig the starter is in front of the engine not at the back. once the screw is undone the clutch will come off and so will the starter cover. neil
Sep 28, 2008 | Troy Bilt Tb70ss Gas Trimmer
No power amd will not drain
This has happened a few times with mine. Turns out, it was a loose ground wire. Here's how to check it: Remove bottom panel (4 screws). In the front(bottom) on the right side there is the electrical connection box. Remove the top screw of the cover and the cover will drop down. There is a screw directly in front on the back of the box. That is the ground connection. Red wire for mine. The screw on mine would only go half way in. Therefore the ground wire was loose causing it to loose power. I replaced with a better screw and it powered back on instantly. Make sure you shut off the breaker before doing this. Good Luck.
Apr 12, 2008 | Dishwashers
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
